Author Topic: New Seat Cover  (Read 8005 times)
vontresc
New Seat Cover
« on: January 10, 2007, 02:35:15 PM »
Well I haven't been here in a while, and the new board is quite nice. On to my question.....
My stock seat has quite a few tears in the cover, and I am planning to get it recovered at a local custom sweing place. Any suggestions for improvements to the seat while I have it apart? also what have you guys used for seat material? It needs to be somewhat sturdy as I store the bike outside during the riding season (no garage).
Thanks
Peter
'82 R-65
Re: New Seat Cover
« Reply #1 on: January 10, 2007, 04:26:17 PM »
The guy who did my seat used what he called marine grade vinyl, if I remember correctly.  It hasn't even been on there a year yet so no longevity reports yet, but it looks and feels good.
Is the seat comfortable for you as it is?
Chris_in_BC
Re: New Seat Cover
« Reply #2 on: January 10, 2007, 05:46:51 PM »
Peter,
 You can order a new stock seat cover from MotoBins in the UK for $35.00 plus shipping if you wanted to keep it looking original.
All depends how much your sewing shop charges you plus cost of vinyl.
http://www.motobins.co.uk/displayfinal.php?function=show&subs=161&title=SEAT+COVERS
Chris
Re: New Seat Cover
« Reply #3 on: January 10, 2007, 06:12:00 PM »
I have used two (R65 nad R100) of the Moto-Bins covers and am not satisfied.  Maybe in colder climates they would be OK but have had both of them start to tear on parts of the heat embossed fake stitching...  Don't know if this is due to the high temps here in the summer, or what...  I still have one more for an R65 that I haven't gotten around to installing yet.
Re: New Seat Cover
« Reply #4 on: January 10, 2007, 10:22:08 PM »
Is comfort an issue for you, vontresc?  That is, do you do much long distance riding - 200 miles or more?
I found that about 5 years ago, I could not ride hardly 1 hour, before it was torture.
I had my seat refoamed 2 years ago, and that made some difference, but I am afraid it was replacing the original shocks last spring that made it all-day comfortable again.
Here is the foam I used: http://www.seatfoam.com/text/INDEX.htm
Not the cheapest product available, but good quality.
« Last Edit: January 10, 2007, 10:22:44 PM by Rob_Valdez_79_R65 »
Re: New Seat Cover
« Reply #5 on: January 10, 2007, 11:08:35 PM »
Rob, what shocks did you use to replace the stockers?
Konis are about impossible to find, and cost a zillion bucks when you do. I've heard some very good things about Hagon, and I know Progressive, Ikon and Works are out there, but what would you personally recommend?
Thanks.
Re: New Seat Cover
« Reply #6 on: January 11, 2007, 12:09:14 AM »
I have 3500 miles on my Hagons.
I liked them not only for the price, but because I could get black springs and black dampers.   8-)
They work fine, or at least they work better than 27 year-old shocks!  My butt likes them, and that is what is most important.
« Last Edit: January 11, 2007, 12:11:04 AM by Rob_Valdez_79_R65 »
vontresc
Re: New Seat Cover
« Reply #7 on: January 11, 2007, 08:26:21 AM »
On long rides it does het a little uncomfortable. I have haerd good things about that temp sensitive foam. How did you go about refoaming your seat? Did you shave the existing foam, and then add the new? I'd be very interested in doing that mod.
On a side note, the PO put on a set of Works shocks. Unfortunately I do not know how long they have been on there, so I was thinking of having them at the very least inspected and recharged. Any of you guys have experience with these shocks?
Thanks
Pete
Re: New Seat Cover
« Reply #8 on: January 11, 2007, 09:42:29 AM »
Hey Pete,
Sorry, I know nothing about your shocks.  If you can't find the answer here, I would post the query on The Boxerworks Forum.  I guess registration can be tough there (ask Sue in Canada), but there is a lot of knowledge there.
As far as redoing the seat foam, the only special tools you will need is a electric carving knife, for shaping the foam, and maybe a pop-riveter for reassembly.  Some spray glue as found in hobby stores is needed.
I took the easy way out and had mine done by a local car upholsterer that was recommended by three different sources for doing bike seats.
Then again, Sue used this same foam for her LS, and she and a friend did the work themselves.
Re: New Seat Cover
« Reply #9 on: January 11, 2007, 09:45:31 AM »
Thanks for the info on Hagon, Rob, that's the direction I've been leaning too.
As far as seats go, I spent months looking for a clean used stocker or good cover to replace my split-up original, and was just about to haul it to the local auto upholstery joint when I stumbled across a like- new Sargent seat on eBay for $90.
That thing made worlds of difference in the comfort level!! ;)
Re: New Seat Cover
« Reply #10 on: January 11, 2007, 01:26:27 PM »
If I may venture: The least instrusive way to insert "memory foam" into your original seat foam is to sit on the seat without the cover on it and taking a permanent marker outline where your "butt" sits. Then cut vertically about 2 inches down into the original foam and take it out. Replace old foam with new memory foam.
This way one doesn't muck up the sides of the seat contour unnecessarily unless you want to reshape the sides..to better reach  the ground with your feet.
My experience and [smiley=2cents.gif] [smiley=2cents.gif]
Re: New Seat Cover
« Reply #11 on: January 11, 2007, 06:40:42 PM »
Sue, you're only entitled to give your two cents, not four...  [smiley=ROTFLMAO.gif]
Re: New Seat Cover
« Reply #12 on: January 11, 2007, 08:03:16 PM »
Justin, did you ever get your LS seat dilemma straight?
Re: New Seat Cover
« Reply #13 on: January 12, 2007, 05:46:04 AM »
It's been kinda moved to the back burner as I have other more pressing projects to deal with.
scottyintex
Re: New Seat Cover
« Reply #14 on: January 12, 2007, 10:45:04 AM »
On e bay there is a brand new seat made in Canada for sale.....price as of 1/12/07 is $45.00
