Author Topic: Power to your plugs  (Read 772 times)
Power to your plugs
« on: March 20, 2009, 06:58:04 PM »
When changing spark plug leads, either for maintenance issues or when installing a new coil, you can insure you're getting maximum voltage and minimum resistance to your spark plugs by soldering the lead's internal wire to the brass coil insert.
Trim back the outer wire sheath to exposed about 3/16" of the wire. After working the wire through the brass fitting, bend and spread the wire threads flat to the brass, then solder.
After a dab of dielectric grease on the fitting, plug the lead into the coil's receptacle. Hot sparks!
Re: Power to your plugs
« Reply #1 on: March 20, 2009, 07:25:55 PM »
Yes, I like neat wiring and good connections, well done but then you're still left with the cheesy screw in connection of the resistor caps.  :'(
« Reply #2 on: March 21, 2009, 06:41:25 AM »
Yes, I like neat wiring and good connections, well done but then you're still left with the cheesy screw in connection of the resistor caps.  :'( rich
Yep. Right, Rich. Other than a dab of dielectric grease and a prayer to both Lord Lucas and Saint NGK that we can screw straight (!).
