Author Topic: tach light  (Read 96 times)
Offline Steve
  • 1979 R65 with 175k miles
tach light
« on: October 17, 2026, 01:50:53 PM »
The light inside my tach no longer comes on. The 8-pin plug on the back of the tach doesn't want to pull out. And having removed the 3 screws in the back of the tach the black plastic, rear part of the tach doesn't want to separate. I hesitate to force these things because the lack of a light doesn't warrant the risk of breaking something. The tach works fine otherwise. Also, I don't even know if the lightbulb is accessed from the back or if you have to take the front glass off.
Offline Tiedie
Re: tach light
« Reply #1 on: October 17, 2026, 05:28:36 PM »
Steve if you have the electronic Tachometer which I'm pretty sure you do. Try a tiny flathead screwdriver and pry lightly all around with care and it should pop off. Then remove the pod and take those 3 screws out and with the same small flathead screwdriver again gently pry all around with care. There's a seal so who don't want to tear it . There are 4 lights inside https://www.euromotoelectrics.com/productdetails.asp?ProductCode=Bulb-3W these are the exact ones you need unless you want to go led then you just gotta get the matching ones. I just changed mine out and what a difference.
Good luck.
Offline Steve
Re: tach light
« Reply #2 on: October 17, 2026, 11:18:31 PM »
Thanks so much. Just what I needed!
