Author Topic: Fuel Filter Choices?  (Read 445 times)
Offline Loan Rider
« on: June 18, 2026, 12:32:54 PM »
I'm curious as to how many people rely on the standard fuel filters built into the tap and use just a fuel line as shown here, and how many add an inline fuel filter as shown resting next to the carb in this photo?
Offline dogshome
Re: Fuel Filter Choices?
« Reply #1 on: June 20, 2026, 08:00:08 AM »
Definitely an inline filter. The one in the tank is a plastic moulding. It filters boulders, icebergs, that kind of thing  :D
Be careful with very cheap filters, the design sometimes doesn't have the filter element completely sealed. Fuel just runs past it. You'll see by looking at it. The big one in your pic is s good one.
Not sure about the little one, although it does look pretty.
Offline Tiedie
« Reply #2 on: June 21, 2026, 09:19:07 AM »
This is the 1 I use. It can be gotten from EME , i change it every oil change.
« Reply #3 on: June 23, 2026, 11:41:50 AM »
I've been using an inline filter for about 40 years .
When I removed the float bowls, I always found a few globs of water and fine gritty sediment .
I currently use a pleated paper element filter, Visufilter 8437-03-9909 . .
If you start using an inline filter be aware that it could be too restrictive .
On the first few various filters I started using, I developed a high speed miss after 15 minutes of  highway speeds .
« Last Edit: June 23, 2026, 12:46:32 PM by Bob_Roller »
Offline Loan Rider
« Reply #4 on: August 01, 2026, 03:00:22 PM »
I do occasionally get what feels a bit like fuel starvation when cruising at 60-70mph and then hit a long uphill section. It seems to go away if I back off slightly, so I do wonder if I have a slight restriction even without a filter fitted.
Offline Tiedie
« Reply #5 on: August 01, 2026, 04:01:23 PM »
Have you serviced your carburetors, just a thought it just could be time to replace some parts. Might not even be a filter issue.
