Author Topic: Lacking spark on R45  (Read 2821 times)
Offline pawepan2
« on: May 12, 2026, 03:31:23 PM »
Hello everyone and thank admin for adding me to the community!
I've been on the forum for a while, but now i have a problem i can't solve myself.
Recently i bought used BMW R45 from 1981yr. - the engine worked pretty fine; motor would start quite easily, i bought it with the new 12V battery.
However i wanted to maintenance it a bit: i serviced carburators (changed orings and gaskets; new gas, clutch and choke pulling lines; i refreshed wheels and put new tyres. I did not service electrical system. Now when I assembled everything all together - motor started nicely, but after a while it died. And i cannot start it with a electric starter or kickstarter.
Now after a little investigation i see that the problem is missing spark at the ignition. When i'm switching killswitch - there is a spark. I made a test with grounding middle connector on the wire leading to ICU - there was a spark at the grounded spark plug.  I checked eletrical connections - it all seems fine. I even replaced ICU module. The coil seems to be fine, as the sparks show up when moving killswitch. The only time i could start the motor was when i launched it on impulse while pushing whole motor - then values shown on the tachometer were irrational. Even when i turn the bike with the key - tachometer shows about 1K for 1 sec without the motor running. The only thing i'm not certain about is the hall sensor - but it worked properly in the past. Can anyone help me solve my problem with the missing spark / lack of proper ignition? Thanks. Now I'm considering installing enduralast digital ignition system.  :bmw_smiley:
Re: Lacking spark on R45
« Reply #1 on: May 12, 2026, 07:15:18 PM »
Hi !! Welcome to the site .
Sounds like you have an electronic ignition from your description .
Check to see if your ignition coil is a dual output black and gray coil .
Notorious for issues case cracking being the most common issue .
Do a check of the primary and secondary circuits of the coil .
Primary resistance 1.5 ohms, secondary resistance  11-13 k ohms .
Offline pawepan2
« Reply #2 on: May 19, 2026, 03:08:02 PM »
Hi, thank you for your response.
I checked on my coil - it took a while.
The primary resistance is 1,5 ohm and secondary is 8,6 ohms - i found on the internet that 8,6 is quite okay. Spark plugs are okay at 5 ohms.
I have one crack on top of the crackomatic coil.
I have ordered enduralast digital ignition system with both coil and two spark plugs. I'm about to check with them.
Offline pawepan2
« Reply #3 on: May 26, 2026, 03:14:03 PM »
I've changed the ignition system for enduralast digital ignition and now it works. Just carb adjustments to be made.
