Author Topic: Snowflake Wheels and Calipers  (Read 4081 times)
« on: April 18, 2026, 02:55:07 PM »
I've got an '81 standard R65 with ATE calipers .
In early 2007 I decided the bike needed some work done to it .
Had about 87,000 miles on it without much done other than routine maintenance performed .
Front rotors for replacement as well as pads .
I went to the EBC website and found rotors and pads effective for '81-84 R65's .
When I got the parts they weren't the correct parts .
The rotors were for composite wheels not snowflake wheels.
The pads were for Brembo calipers not ATE caliper.
You can alter pads for Brembo's to work on ATE calipers .
BMW used ATE calipers into the '82 model year until they used all of remaining stock of parts .
Sometimes even the parts catalog gets it wrong !!
« Last Edit: April 19, 2026, 03:47:57 PM by Bob_Roller »
Offline Tiedie
Re: Snowflake Wheels and Calipers
« Reply #1 on: April 19, 2026, 09:39:25 AM »
When I gothe parts they weren't the correct parts .
Did you just get the parts of have you had them awhile? If you just got them then return as wrong items delivered, I wouldn't alter or modify breaks for any reason it is your life and saftey as well as others.
Just that Big Truck driver in me speaking.
« Reply #2 on: April 19, 2026, 02:25:33 PM »
I altered the steel back plate on the pads .
Trimmed some metal off .
The pads for the Brembos go straight across with one small groove for a pin .
The ATE pads have two  ears where the pins go through so I removed about 6 - 7mm .3 inches from the back plate.
There is still .25 inches, 6 mm of back plate before you get to the friction material .
I did this work 19 years ago .
I returned the rotors and got the correct EBC steel rotors .
« Last Edit: April 19, 2026, 03:52:58 PM by Bob_Roller »
Offline Tiedie
« Reply #3 on: April 20, 2026, 06:21:35 PM »
 :tekst-toppie:
