Author Topic: Battery for '79 R65 (AGM)  (Read 13108 times)
Offline TomHoldom
« on: March 27, 2026, 04:15:01 AM »
Hello,
I'm looking for help recommendation for an AGM battery for my occasionally used 1979 R65
My old AGM battery is dead (after forgetting to leave on trickle charge of winter)
I have seen an Exide AGM12-18 (12V, 18Ah, 250A) recommended which is available where I am (france) for ?65.
Does this look ok? After the size and quality is it only the 12V and 18Ah that I need to check when choosing ?
Thanks for your help.
Tom
Re: Battery for '79 R65 (AGM)
« Reply #1 on: March 27, 2026, 02:07:38 PM »
That's not a bad price .
I have been using generic agm batteries for 25 years .
I live in a low desert and batteries last at best 3 years .
Do an online search for agm motorcycle battery 12 volt 22 ah and see what you come up with .
There are 18 and 20 ah batteries available I've been using the higher ah batteries they seem to last a little bit longer than the 18 ah batteries .
See if you can do better on the price shipping costs may outweigh the savings .
Also I would recommend using a battery tender if the bike isn't ridden often .
Get a quality tender I went cheap and had early battery failure .
I'm sold on Battery Tender brand, they have the Junior Tender 750, 800 ma and 1 amp tenders .
« Last Edit: March 27, 2026, 03:10:14 PM by Bob_Roller »
Offline Tiedie
« Reply #2 on: March 27, 2026, 05:48:27 PM »
Hello,
Tom
Ive had excellent success with the Odyssey PC680 for the last 15 years or more. As Bob mentioned Battery Tender brand is excellent been usins one for 30 years or more and upgraded to a 4 bank to run the lawn tractor, the LS and my Kubota B7100 tractor. Have one in the garage for my generac generator too.
When everything gets put up for the winter I plug up and it maintains.
Oddyssey owns X2 power batteries by the way.
« Reply #3 on: March 28, 2026, 11:26:33 AM »
Another vote for generic AGM's. My first one cost GBP32 and  lasted almost 11.5 years. I recently replaced it with another very similar battery for GBP35.
PC680's are great batteries but at GBP140 in the UK they they make no economic sense at all compared to a generic AGM.
That's strange, I type pounds signs and it displays pounds signs until it's saved and posted when they then turn in to ? marks.  So I've used GBP instead
« Last Edit: March 28, 2026, 11:31:29 AM by Barry »
Offline TomHoldom
« Reply #4 on: March 28, 2026, 11:29:08 AM »
Thanks for the help
