Author Topic: LED Replacement for H3 Bulb  (Read 5730 times)
Offline Charlie
« on: November 25, 2025, 07:30:28 AM »
Is there a direct LED replacement for an H3 bulb.
If not, I have a lot of experience with Jack Legging a solution, sometimes successfully.
I use 2 H3 bulbs in inexpensive (cheap) light housings to add 70w to the High Beams.
Works very well too. I have used these for +- 40 yrs.
Bulbs will be cheaper than a higher output Alternator for a newly aquired ‘83 R65
Offline Charlie
Re: LED Replacement for H3 Bulb
« Reply #1 on: December 01, 2025, 10:13:39 PM »
“Pauls1150” on the MOA Forum (Airheads Catagory) posted these suppliers.
Thanks ‘Paul’s1150’
Auxito has "fog lights", which may imply that they're not bright enough for headlights -
auxito.com
AUXITO H3 LED Fog Light Bulbs 6500K White with 8 CSP chips
The position of the miniature H3 LED fog light bulb overlaps nicely with the halogen bulb position. 3000k golden light output gives you more visibility in bad weather!
 auxito.com auxito.com
Same caveat at Revzilla -
www.revzilla.com
PathfinderLED Hi-Powered H3 LED Passing Lamp Bulb For Harley Softail / Touring - RevZilla
Shop RevZilla for your PathfinderLED Hi-Powered H3 LED Passing Lamp Bulb For Harley Softail / Touring today! Free Shipping, Lowest Price Guaranteed & Top of the Line Expert Service.
 www.revzilla.com www.revzilla.com
They also have 35 and 55 watt halogens -
www.revzilla.com
Drag Specialties H3 Halogen Headlight Bulb - RevZilla
Shop RevZilla for your Drag Specialties H3 Halogen Headlight Bulb today! Free Shipping, Lowest Price Guaranteed & Top of the Line Expert Service.
or
maybe SuperbrightLEDs -
Search Results | Super Bright LEDs
 www.superbrightleds.com www.superbrightleds.com
or
Cyclops - https://www.cyclopsadventuresports.com/H3-LED-Headlight-Bulb-2800-lumen_p_134.html
I ordered a couple from www.superbrightleds.com
Charlie
