Author Topic: Bing 32mm piston slide orientation  (Read 4873 times)
Offline R65TR6
« on: October 30, 2025, 01:24:09 PM »
Dumb question. Do the cut out arches on the slide go with the direction of the airflow, or 90 degrees from it??  I assume go with the flow, but some Bing diagrams show the piston turned 90 degrees.
Thanks
SR.
PS I bought my R65 new in 1986.  Still have it.
Re: Bing 32mm piston slide orientation
« Reply #1 on: October 31, 2025, 04:06:39 AM »
The cut outs on the bottom of the slide go with the flow and just as important is to get the slide the right way around. Look on the bottom of the slide and you will see a small hole that communicates the vacuum signal to the top of the diaphragm. The slide should be orientated so the hole is nearest the butterfly.
Offline R65TR6
« Reply #2 on: October 31, 2025, 05:19:36 AM »
Thank you!
« Reply #3 on: October 31, 2025, 06:06:00 AM »
Hello,
If your bings have a dome shaped top, the diaphragm has two notches, ont on the piston side, one on the body side which ensure you do not mess the orientation.
If your bings are the flat domed one, you "normally" can't mess the orientation because the diaphragms are not replaceable ... But if you are careful this can be done and, thus, you need to take extra care to respect the proper orientation of the piston in the body...
Hope this helps
Offline R65TR6
« Reply #4 on: October 31, 2025, 01:16:01 PM »
Thanks.  Mine have no notches, but are now correctly oriented with vacuum holes on the butterfly side.  One carb now clean and assembled, one to go yet.
But now that you mention it, I was curious as to why there wasn’t an alignment notch.  Guess there are in some versions.
