Author Topic: leftover o-rings from carb rebuild kit  (Read 1718 times)
Offline davenerk
« on: July 10, 2025, 10:55:19 AM »
i ordered a carb rebuild kit for my 1986 r65.  no problem rebuilding the thing but i couldnt figure out where the circled o-rings go.  i only found three places for o-rings.  1.  the idle jet 2. mixture screw 3. main needle jet.  where do these two other o-rings go?  i looked at the exploded view of the carb and couldnt see a spot.  32mm bing.
i feel silly even asking but... its worrisome when there are parts leftover.
Offline dogshome
Re: leftover o-rings from carb rebuild kit
« Reply #1 on: July 10, 2025, 02:21:58 PM »
Hiya,
Throttle shaft (I didn't bother as it wasn't leaking) and choke mechanism shaft :-)
Offline davenerk
« Reply #2 on: July 10, 2025, 02:40:38 PM »
i would never have guessed those. but it’s good to know they are there and i have spares!
thanks
« Reply #3 on: July 11, 2025, 01:43:33 PM »
Hi !
Doing a full carb review, I think it would be wise to check on the throttle shaft O-rings.
If they are worn, you'll have an air intake which won't help when tuning them...
Be careful with the screws holding the butterfly and use new ones carefully preened upon installation.
Just my 2¢ ...
