Author Topic: Forks topping out with a clunk  (Read 1789 times)
Offline svejkovat
« on: July 01, 2024, 02:10:54 PM »
This has bedeviled me for decades.  As I weight  and unweight the front end while on the centerstand my forks top out with a 'clunk'.  Occasionally when travelling at slow speed over extremely uneven pavement,  or a deep pothole, or off of a mild sized curb, the forks will unload completely with a pretty jarring clunk.
Previous owner tried to remedy the early boxer endemic speed wobbles with stiffer progressive springs,  new steering bearings, and heavy frame guard (the tubes that protect the cylinders).
So the stronger springs may contribute to topping out too soon.
But the clunk seems wrong.  And not too healthy for the steering bearings.
I've rebuilt the forks myself and looked at schematics.  All seems assembled in the right order with nothing missing.  What might be going on here?
Re: Forks topping out with a clunk
« Reply #1 on: July 01, 2024, 04:17:13 PM »
Ok this is a long story that I've investigated and experimented with for years.
To cut to my opinion of the cause, the forks clunk when they top out for two reasons, they have a topping out bush rather than a spring which is very unusual and the rebound damping is insufficient particularly over the last inch of travel when the rebound damping should increase substantially to provide a bump stop effect but doesn't or didn't on mine.
Here’s how the forks work.
Compression Damping
During fork compression oil is displaced from the lower fork leg into the stanchion. It passes through the compression damping holes in the bottom of the damper rod and also through the  annular gap between the damper rod and valve body lifting the valve washer up against the valve plate. The degree of compression damping is determined by the size of the compression damping holes and the oil viscosity
Rebound Damping
As the forks extend the damper piston forces oil back into the lower fork leg.  The valve washer drops and seals against the valve body and the oil can now only pass through a small 3mm hole near the top of the piston damper rod. This is the rebound orifice. The area of this hole is smaller than the area of the compression damping holes by a factor of 3 resulting in approx 3 times stiffer rebound damping relative to compression. That figure is typical as rebound damping is always substantially stronger than compression damping. During the last 25mm or so of extension this hole drops below the valve washer so there is nowhere for the oil to go except by leakage past the washer and to a much lesser extent past the piston rings. This is meant to be the rebound hydraulic bump stop and its efficiency will depend on the leakages mentioned. Variability here may explain why some owners have problems with topping out clunk and others do not. In my case the area of leakage past the valve washer was twice as much as through the rebound hole proper so there was very little effective hydraulic bump stop effect. In making my own valve washer I reduce the washer to piston rod clearance to cut the leakage in half and this eventually  eliminated the topping out noise when I got the clearance right. Why didn't BMW get this right in the first place  - I think it's because you can go too far in reducing leakage and the forks will tend to hydraulic lock on rebound.
When the thicker chamfered valve washer was introduced the washer to piston rod clearance was reduced which reduced leakage and therefore improved the rebound hydraulic bump stop.
What I strongly recommend you do is remove the springs leaving the oil in, then stroke each leg by hand to feel the damping. You should feel compression damping hardly at all but rebound damping should feel stronger and there should be a definite increase over the last inch of travel If you don't feel that increase then it's going to clunk for sure.  The cure is to reduce the leakage past the valve washer by closer tolerances. BMW modified the valve body and washer several times in an attempt to improve the forks The first iteration was a solid valve body and steel washer which is what I had, then they changed the washer for a thicker plastic washer with tighter clearances and less travel, the recess in the valve body was made deeper to match. Another source of noise is movement of the valve body in the stanchion, the valve body was initially loose then they shimmed it to prevent it moving, then used a sort of sprung washer and eventually a shorter sprung valve body was used. All these things were an attempt to stop the valve body rattling but the sprung version may also help with the clunk too.
You are absolutely right to suggest that stronger springs will make the problem worse by overcoming the rebound damping even more.
In my opinion an R65 is the last of the airhead models to need stronger springs unless the rider is well above average weight.
« Last Edit: July 01, 2024, 04:29:06 PM by Barry »
« Reply #2 on: July 01, 2024, 05:04:57 PM »
When you reassembled the forks, was the top cap under tension from the fork spring ??
Some after market springs are shorter than the OEM springs and require a spacer between the spring and top cap .
Usually it's a short piece of PVC tubing .
Curious what weight oil and the quantity of oil you put in each fork .
Offline svejkovat
« Reply #3 on: July 01, 2024, 06:29:06 PM »
Looks like it's time to dig into these one more time and look for a remedy.  Thank you guys SO much for the input here.
...they top out for two reasons, they have a topping out bush rather than a spring which is very unusual...
Is there insufficient space to replace that bush with a spring?
I am encouraged by ideas you suggest. This will definitely be a Fall project.
« Reply #4 on: July 02, 2024, 02:28:59 AM »
No nothing like enough space as the original bush is quite thin.   The original bushes were rubber which tended to disintegrate over time. Replacements seem to be a much harder plastic bush which can't be helping. If softer rubber bushes could be found that must help even if they required routine replacement.
The otherwise near identical forks on the R80st did have a topping out spring although the stanchions are longer to allow for that. Fitting a topping out spring to our forks would lower the front end substantially.
Offline svejkovat
« Reply #5 on: July 02, 2024, 11:39:29 AM »
Well thank you all deeply for clearing this up so well.  I'd had many moments of doubt about the real source of this. For many years now.  From loose steering head bearings to something clunking under the tank somewhere.
But with the information you've provided, the facts that the previous owner installed stronger springs, and that I weigh 150lbs and ride almost exclusively without passengeror baggage, it would seem to me I know now exactly how to proceed with some remedy.   I'll look more into tweaking the flow rate of oil in n the rebound.
But a Fall project.
Thanks again
