Author Topic: Rear subframe compatibility  (Read 1691 times)
Offline Dwmadsen
« on: May 05, 2024, 10:09:22 AM »
Will the upper tail section for the 1986 R65 bolt to a 1981 R65 rear subframe?
Offline dogshome
Re: Rear subframe compatibility
« Reply #1 on: May 05, 2024, 11:23:00 AM »
No, unless you want to buy a lot of other parts as well.
Up until 1985, the bikes were short wheelbase. Shorter swingarm, smaller battery, different seat, toolbox and fender/mudguard. After that, they went to the same size as the R80/100 etc. It's about 2" longer from memory. The fittings between the frame and subframe also altered. There is a load of info about this on the web once you know about short and long wheelbases.
« Last Edit: May 05, 2024, 11:24:43 AM by dogshome »
Offline Dwmadsen
« Reply #2 on: May 05, 2024, 07:18:52 PM »
Thanks! My issue is the real rear cowling leaves a large vertical gap between the bottom of the cowling the the fender : https://share.icloud.com/photos/0dffukkx6bEZWsuRB_83G-1dg.
I am looking to “fill the gap”. The parts list seems to list only the rear cowling I presently have. Images of other R65s show a rear cowling which hangs lower.
Offline donbmw
« Reply #3 on: May 05, 2024, 08:02:58 PM »
« Reply #4 on: May 06, 2024, 05:22:31 AM »
And the rear subframe is for two shock absorbers on the 1979~84 models and mono shock absorber for the 1985~95 models...
Offline Dwmadsen
« Reply #5 on: May 06, 2024, 03:19:15 PM »
Don,
Perfect….this explains my dilemma.
Offline dogshome
« Reply #6 on: May 07, 2024, 05:13:23 PM »
Hes right   :)
The toolbox mounts on the two bolts you can see that have black plastic caps on them currently.
« Reply #7 on: May 08, 2024, 01:30:28 AM »
Do not forget to install the metal strip ABOVE the toolbox in order to spread the load on the plastic ....
