Author Topic: Brakes  (Read 750 times)
awaffa2003
Brakes
« on: February 10, 2009, 11:29:51 PM »
I need new brakes all around. the rear is almost gone from this summer when i got my rim to discolor and smoke from flying down the highway with that stupid wing nut too tight... the front is shot, rotors are grooved and I suppose this means that my pads are finished too, went to wyoming like that too  :-/ anyway I need new pads/shoes, new rotor, and stainless brake line. probably gonna go speigler with the line seeing as i just put a couple of their decals on my tank lol. possibly thinkin about going dual disk too. hell i might even buy one of those radial master cylinders while i'm at it!....maybe not, altho i did pick my dad's lotto numers tonite. What products have you guys felt most comfortable with? Could i just change my pads and let them conform to my rotors cuz i doubt i have rotor money right now.
Re: Brakes
« Reply #1 on: February 11, 2009, 03:38:07 AM »
If your rotor is knackered then change both pads and rotor at the same time - you are wasting money otherwise.
What thickness is the rotor? And is it cracked (between holes) - normally accompanied by some high pitch squeeling.  If it has some meat on it and is not cracked, then you have some slack.
I would pull the pads and see what you got left first - it will take time to bed in some new ones - which you will have to throw away when you get a new rotor, if the original is that bad.
Significant improvements to a single disk set-up can be made before going to the cost of a dual disk setup - and none of which will be wasted, if you are careful.
Ask yourself some questions.  Am I loaded down with pillion, heavy fairing and luggage all the time?  Am I a riding god who would be better off on the race track?  If not, then you might not need dual disks at all, just a refresh of the existing system - which does sound like it could do with some attention.
Dual disks will mean you have two of everything to change - and will increase you unsprung weight at the front.  You will need a new master cylinder, a new brake line, a new caliper and another rotor, plus bolts, etc.  A significant investment on top of your existing costs.
I actually went the other way - I went from a dual disk to a single disk set-up.  What I lost in outright power, I gained in loss of weight, progression and feel.  I am happy with the single disk setup.  In the UK most R65's are sold with a dual disk set-up.
There are several common choices with disks:
1.  Original equipement - not the best, but not unreasonable - often replaced with better aftermarket options when they wear out.  But not worth doing until that time.
2.  PFM Cast Iron disks (I have a set of these on my R100) work well but discolour(rust) when wet.  A common replacement for when originals wear out and good wet weather performance.
3. EBC Pro-lites, full floating disks, that are lighter that originals and the cast iron disks.  I had some on a K100RS some years ago and were a definate step up from the original equipment.  Most expensive option - but if you only have 1 disk to replace....You could push the boat out.
4.  Grimeca - popular replacement and look exactly like originals.  I however was not pleased with mine when both warped after minimal mileage (circa 10,000 miles).  But I am willing to accept that I might have had some of a bad batch, as others have had no issues.
If I were you, I would improve the single disk setup first, and see how you go.  If the improvement is not sufficient then go for the dual disk setup, at least you will have a staged approach that will spread the cost.
Steve H
« Last Edit: February 11, 2009, 03:43:16 AM by steve_hawkins »
Re: Brakes
« Reply #2 on: February 11, 2009, 01:44:34 PM »
Money is tight, but you are thinking of radial calipers?  Hmmm...I think someone's age is showing! ;)
Don't be embarrased - my head is in the clouds 90% of the time.  It is seeing posts from young folk like yourself that gives me some perspective!  I thank you. :)
I rode with grooved a rotor (the original) for a LONG time (80,000+?).  Don't let that worry you as much as cracking or warping.
Gotta go - just got invited to some home-cookin'!
