Author Topic: Carb overhaul, now running rich.  (Read 1512 times)
Offline MikeFossl
« on: December 25, 2021, 01:59:32 PM »
I did a complete carb cleanup and replaced all gaskets, o-rings and bellows.  Stats fine but having trouble getting an even idle.  Checked plugs and shows even coat of carbon.  Replaced plugs with new and after a couple of minutes at idle and a 5 min ride, the new plugs show another even coat of carbon.
Tried to adjust idle mixture but did very little.  Currently at 1 turn out.
Any suggestions?
Thanks,
Mike
1985 R65
Offline donbmw
Re: Carb overhaul, now running rich.
« Reply #1 on: December 25, 2021, 02:41:58 PM »
Soak the carbs in cleaner again. Still have a passage stopped up.
Offline dogshome
« Reply #2 on: December 25, 2021, 05:07:13 PM »
(1983)R65 idle screw start setting is 0.5 turns out. I have mine leaner than that with silent hektic ignition. 1 turn is far too rich. Check 1985 with your carb number here.
https://w6rec.com/wp-content/uploads/2017/07/Page2-2.jpg
Offline wilcom
« Reply #3 on: December 26, 2021, 12:30:57 AM »
If you are not getting adjustment when you turn the idle jets you have a passage fouled. Blow carb cleaner thru them till they all squirt cleanly. The attached animation is a good picture of what you're after.
https://www.youtube.com/watch?v=wyspAHrMbb8
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline MikeFossl
« Reply #4 on: December 26, 2021, 11:21:16 AM »
This is likely the issue.  I was following a general airhead carb rebuild video.  Thanks for that resource.  Once the snow melts I'll clean the plugs, start at 1/2 turn and try again.
Thanks!
1985 R65
Offline MikeFossl
« Reply #5 on: February 13, 2022, 03:34:02 PM »
Finally a warm dry day….dialed back to 1/2 turn.   Running like a top.
Thanks!
1985 R65
Offline dogshome
« Reply #6 on: February 14, 2022, 04:39:54 AM »
Thanks for the feedback, glad it is running well.
