Author Topic: Spline lube  (Read 1277 times)
Offline jp9094
Spline lube
« on: April 15, 2021, 02:59:08 PM »
I had all the splines cleaned and lubed on my 1983 r65 LS at 45600 miles. The bike now has 51000 miles on it and I need to replace the back wheel with a used one. The question is, should I lube the splines on the replacement wheel. If so, what should I use?
TIA
Offline donbmw
Re: Spline lube
« Reply #1 on: April 15, 2021, 07:04:50 PM »
I lube the wheel splines every time I have the wheel off. When did you lube the input shaft splines on the transmission. They recommend every 10000 miles.
Re: Spline lube
« Reply #2 on: April 15, 2021, 10:13:08 PM »
I lube final drive to wheel splines every tire change and the transmission input about every 20K miles
I don't think 10K is necessary I am not even sure 20K is
Re: Spline lube
« Reply #3 on: April 15, 2021, 11:49:49 PM »
Same as above here. For the grease, I use Molykote BR2 because it was once BMW  spec and my dealer has it. Ask the industrial parts dealer (the guy which sells roller bearings, O-rings, hoses for the industry) and equivalent of the BR2 and you are good to go.
Re: Spline lube
« Reply #4 on: April 16, 2021, 11:40:19 AM »
I tend agree,  wheel splines every tyre change and transmission input splines once in a long while. I have 20,000 miles since doing them last and notice no problems with gear change quality.
