Author Topic: HEI ignition system conversion  (Read 3358 times)
Re: HEI ignition system conversion
« Reply #15 on: March 13, 2021, 11:04:42 AM »
The energy savings is quite substantial at Idle
This is with LED head light ,LED front park light and LED tail light
Dash lights are incandescent
I could easily run more heated gear on top of my vest and grips
14.4 volts I think that is a record  ;D
Offline dogshome
« Reply #16 on: March 13, 2021, 01:45:17 PM »
Aha, so That's what you did with the clutch cable :-)
Yea, nah, can't get that voltage at idle. Where is the temple/altar/we-are-not-worthy smiley?
Good job  8) 8) 8)
« Reply #17 on: March 13, 2021, 07:42:11 PM »
Sure isn't pretty  :P
After installing the RT bars. The cable had to make a hard bend to get under the dash pad
 So I drilled a hole thru the dash to straighten it out and  extend the life of the cable
