Author Topic: R45 to R65 upgrade  (Read 5003 times)
Offline dogshome
R45 to R65 upgrade
« on: November 19, 2020, 12:59:25 PM »
Hi all, the 860 kit is staying, so I may as well sell the 650 pistons and barrels. They are the 1981 plated type (1983) with base O ring groove.
I believe the block is the same on R45s, also pushrods etc, but don't know about the head or whether the 650 parts can be simply fitted or if some machining or compression reducing base gaskets etc are required. From photos it looks like the edges of the 650 pistons might hit the wider gasket area of the 450 head. The 650 pistons do have a flat band at the edge and don't pop-up, but it's hard to tell. Of course it might simply result in 15:1 compression......
Since the head gaskets on all are the same apart from the 1000 and combined with my rough pic below, this seems to confirm the head will fit the barrel. But will the piston hit the head?
I'd like to know as someone is bound to ask now!
« Last Edit: November 19, 2020, 01:35:27 PM by dogshome »
Offline dogshome
Re: R45 to R65 upgrade
« Reply #1 on: November 23, 2020, 01:59:50 PM »
They look in reasonable shape.
Yes I can feel every original finishing tool mark all down both sides of the skirt. I never had a Yamaha piston like this after 30,000, let alone 60,000!
The bore though has some ring polishing marks at the top and I can feel a tiny ridge on the top of the first compression ring mark. So worn and a ring replacement not possible, but will do another tens of thousands I expect. She was losing no oil or smoking.
Collective thoughts?  :lurker:
« Last Edit: November 23, 2020, 02:13:53 PM by dogshome »
« Reply #2 on: November 23, 2020, 02:34:59 PM »
I'd just stuff the slugs back in the same jugs and run 'em!  When I freshened up the Junkyard Dawg the oil rings had an excessive end-gap and it smoked like crazy.  I just scuffed the cylinder walls with a Scotch-Brite and put in new rings.  Ran great!
Offline dogshome
« Reply #3 on: November 23, 2020, 04:10:09 PM »
If I'd not just fitted some shiney new big ones, that's what I'd be doing. I think they are good for a few years, but not another 60,000.
Do they fit a 450? Would 450 heads then need a bit of milling to reduce compression or just base shims or fit right in?
« Reply #4 on: November 23, 2020, 06:41:09 PM »
I have no idea but there are a couple of 450 folks on here that might be able to shed some light.  Have you looked up the part numbers for both heads?  I would think that maybe a thicker head gasket or flatter piston top would get compression under control.
Offline dogshome
« Reply #5 on: November 24, 2020, 12:50:24 PM »
Probably yes. But no-one seems to talk about it  :(
More on liners. This is ring gap in worst worn spot.
Offline dogshome
« Reply #6 on: November 24, 2020, 12:54:14 PM »
The gap on the hardly worn area further down.
This is 0.05 smaller, so divide by pi gives 0.016mm. Wear (taper) limit is 0.02mm. I don't know if this is a wear limit or a manufacturing limit. Either way it ain't knackered. Worn, but not worn out.
« Last Edit: November 24, 2020, 12:56:29 PM by dogshome »
« Reply #7 on: November 24, 2020, 09:41:17 PM »
Hopefully somebody will chime in.  The site traffic is down considerably this past year due to various issues but hopefully now that things appear stable people will start coming back...
Offline dogshome
« Reply #8 on: February 06, 2021, 10:43:05 AM »
Well a gentleman in Spain bought them as spares for his 650. That was well before Christmas. I just got notification from Hermes that they finally got there. I also got a tracking record. This parcel has more tracking than than Donald Trumps Twitter account ever had!
29 pages. I think Michael Palin, Chris Tarrant or Sir David would be jealous of its journey. Starship mileage!
« Last Edit: February 06, 2021, 10:45:58 AM by dogshome »
« Reply #9 on: February 06, 2021, 10:27:50 PM »
The US Postal service is so messed up from covid that is took me 4 days to get a bulb from Superbright LED
The problem is they are only 10 Miles away  :o
« Last Edit: February 09, 2021, 10:32:36 PM by mrclubike »
« Reply #10 on: February 07, 2021, 10:47:20 PM »
I've had several packages go through the St Louis Hub lately that seem to get stuck there for several days...  :furious3:
« Reply #11 on: February 08, 2021, 11:12:43 PM »
As to the topic of R45 and R65 cylinders & head compatibility
Both R45 and R65 models of the same vintage (either pre-Nikasil (< 1980) or Nikasil (1981-86(( had the same 61.5mm stroke, but the
R45 bore was 70mm, whereas the R65 bore was 82mm.   That half an inch diameter difference up at the head could have issues.  Along with this, the R45 head uses smaller valves (In 34mm, Ex 32mm) versus the R65 (In 38mm Ex 34mm for pre 1980, In 40mm, Ex 36 for 1981-1986) so you really do need to swap heads for the larger R65 valves to get the benefit.   Even if the 12mm "step" in the R45 heads can be worked around, the smaller valves will dramatically reduce the power gain achievable with the R65 cylinders in place.. But, at least the connecting rods are the right length (I am assuming the wrist pin diameters are the same - maybe they aren't)?
