Author Topic: Footpeg Rubbers  (Read 1216 times)
aussie
Footpeg Rubbers
« on: December 29, 2008, 07:50:10 PM »
I managed to score some NOS footpeg rubbers for the front awhile back. I've tried getting the old ones off but am not having much luck... Can anyone tell me - do they just pull off? It appears as if they should but, Hell, I can't budge 'em.  :'(
Re: Footpeg Rubbers
« Reply #1 on: December 29, 2008, 08:15:58 PM »
I was able to get mine off after lots of tugging and twisting, but later realized I could have taken a razor sharp box knife to it and saved myself a great deal of trouble.   Putting the new ones on was a pita as well.  Probably should have used soapy water, or gasoline to lube it first.
Good luck,
Ed
Re: Footpeg Rubbers
« Reply #2 on: December 29, 2008, 09:00:41 PM »
I have found an excellent lubricant for rubber parts is silicone spray lubricant.  It is easy to use, and evaporates.
Any auto parts store should have it.
scarygary
Re: Footpeg Rubbers
« Reply #3 on: December 29, 2008, 11:09:55 PM »
I changed mine out as well.. went with Windex as a lube... (water is just as good).
aussie
Re: Footpeg Rubbers
« Reply #4 on: December 30, 2008, 12:30:24 AM »
Many thanks guys. Ed - I was seriously thinking about cutting them off before I posted - but I just have this thing about destroying stuff - even if it is knackered.....that probably explains a lot now that I come to think of it.....hmmm.
Rob - you're a life saver - six squirts of silicon lube on each side and off they came in twenty seconds!
Praise the Lord and pass the silicon  ;)
Tim
