Author Topic: HID Conversion  (Read 5140 times)
HID Conversion
« on: February 04, 2008, 09:21:13 PM »
I installed an HID conversion kit in my '95 RT over the weekend, it's BRIGHT!!!
Re: HID Conversion
« Reply #1 on: February 04, 2008, 09:57:43 PM »
What bulb?  What kit?  I love HIDs.
Re: HID Conversion
« Reply #2 on: February 04, 2008, 10:17:28 PM »
Re: HID Conversion
« Reply #3 on: February 05, 2008, 12:35:26 PM »
That's not bad.  Can you figure out from the packaging how much current the thing draws?  Not any claims of "90 watt output" or the ilk, but just how many watts it uses?
Also, and I know this goes in a different section, but do you think that would work with a positive ground system?
Can you see good both with the shielded low beam and the high beam?
Thanks,
Re: HID Conversion
« Reply #4 on: February 05, 2008, 12:49:44 PM »
Did you run a complete new harness for the HID, and then use the OEM wiring to activate the relay for the HID ?
I'm kind of curious what kind of bulb life to expect out of a motorcycle installation, my average for the PIAA halogen H4 bulb is about 24 months.
Re: HID Conversion
« Reply #5 on: February 05, 2008, 05:30:20 PM »
Ed, I have not personally installed an ammeter in line with the ballast but the web site states they draw about 35% less than the bulb.  So, if the low beam H4 dissipates 55 watts that would work out to about 4.3 amps.  So lopping 35% off that would leave you with a 2.75 amp current draw for the HID.
Bob, it comes with a fused wiring harness and relay that you hook directly to the battery and the headlight connections are just used as control signals.  As far as life, who knows...  The web site claims up to 10x longer life than a bulb...
Re: HID Conversion
« Reply #6 on: February 06, 2008, 07:36:29 PM »
Are those the lights that make me curse oncoming traffic?
Re: HID Conversion
« Reply #7 on: February 06, 2008, 07:41:04 PM »
Maybe, but I didn't go with the obnoxious blue ones - pure white...  ;D
« Last Edit: February 06, 2008, 07:41:46 PM by admin »
Re: HID Conversion
« Reply #8 on: February 06, 2008, 07:48:26 PM »
What color did you get the 5000 degree Kelvin, bulb ?
Re: HID Conversion
« Reply #9 on: February 06, 2008, 08:42:51 PM »
Yes, Bob, very happy with the color of the light.
« Last Edit: February 06, 2008, 08:43:22 PM by admin »
Re: HID Conversion
« Reply #10 on: February 06, 2008, 09:30:00 PM »
5K is the color I got for my car too, as it was the closest to the Sun's color which I believe is around 4500.  White, basically, though it looks blue compared to yellow halogens.]
Now I hope you'll let us know how long that moving part (the shield that switches you from high to low beam) lasts....  That's my only concern with the H4 versions.
And would positive ground make any difference?
Re: HID Conversion
« Reply #11 on: February 06, 2008, 10:30:15 PM »
Yeah, the moving part.
Any idea how that works?
Re: HID Conversion
« Reply #12 on: February 06, 2008, 10:38:42 PM »
I sent the company an email, on what moves the shield to switch from low beam, to high beam.
See if I get a response.
Re: HID Conversion
« Reply #13 on: February 07, 2008, 06:18:02 AM »
Yeah, funny you should mention that.  :-?  My shutter operation has turned somewhat erratic so after following some troubleshooting steps provided by the vendor it appears they will replace the bulb.  The "shutter" seems to be actuated by a little solenoid (or tiny gizmo like a door-lock motor) and in the at-rest position it is in the "low beam" position.  On mine sometimes the shutter doesn't actuate unless I provide a wee bit of a tap to the rear of the bulb - seems like the mechanism is sticking or binding, or something...
Re: HID Conversion
« Reply #14 on: February 07, 2008, 07:09:03 PM »
I recieved a reply from the company, and it states that 'there is a motor in the back of the bulb that moves the bulb up and down to get the high and low beam'.
Sounds kind of interesting, can you get a picture of this Justin ?
