Author Topic: Sprucing up the old R65...  (Read 116190 times)
Offline Adrian
  • The Old Hairy Biker Sez...
Re: Sprucing up the old R65...
« Reply #105 on: October 13, 2016, 05:53:02 AM »
Having got sidetracked into making a new backrest pad I finally started on the seat tray. Here is the thing with all the paint removed and a gentle rub over with some very fine wet/dry paper. Soon to be black - once the weather improves for spraying :-)
« Last Edit: January 17, 2021, 11:17:49 AM by Justin B. »
1984 R65 (860)
Offline Adrian
« Reply #106 on: January 22, 2017, 10:26:16 PM »
Okay finally the resto is back on track - So even though it gets to 40 degrees C sometimes - I'm back in the shed at last. What's that about mad dogs and Englishmen????
The new lift tray is great - here's the start today of the sub assembly attached back to the frame - no bending down any more - woohooo
The other picture is the centre stand attached - but my first problem has arrived.
How do I attach the springs to the Centre stand and frame? I have given it a quick try with bent nose pliers - and that wasn't very successful.
So any help is going to be very much appreciated thanks   Adrian
« Last Edit: January 17, 2021, 11:20:04 AM by Justin B. »
1984 R65 (860)
Offline Adrian
« Reply #107 on: January 22, 2017, 10:26:47 PM »
The spring .......
« Last Edit: January 17, 2021, 11:20:29 AM by Justin B. »
1984 R65 (860)
Offline Adrian
« Reply #108 on: January 22, 2017, 10:28:40 PM »
And why is it only possible to post one picture at a time now???
1984 R65 (860)
« Reply #109 on: January 23, 2017, 10:29:02 AM »
Looking like some nice work Adrian.
Not sure about the issue of one image at a time, I had some issues with this a while back, but it may have been me not the forum! Check out that thread, it might help.
Offline Adrian
« Reply #110 on: January 23, 2017, 09:19:44 PM »
Panic over - I saw a photo of a spring puller on another forum - so this photo is my version - a large set of mole grips and a very small allen key I found in the bottom of my tool box - suitably bent.
The spring was so easily stretched and went onto the small ring on the centre stand with no problems whatsoever.
Sometimes I surprise myself  ;D
« Last Edit: January 17, 2021, 11:21:21 AM by Justin B. »
1984 R65 (860)
« Reply #111 on: January 24, 2017, 02:14:38 AM »
It's great when you get help and then fix it yourself!
« Last Edit: January 17, 2021, 11:21:54 AM by Justin B. »
Offline Adrian
« Reply #112 on: January 24, 2017, 06:17:16 AM »
Thanks Chris  ;)
1984 R65 (860)
Offline Adrian
« Reply #113 on: February 01, 2017, 04:57:01 AM »
So a little more has been done - swing arm on - bevel drive and the suspension units too. I forgot to order washers for all the nuts and plugs and filler bolts and all that - derrrrrrr must have had  seniors moment or two.
Anyway thanks to the quick and efficient mob in Western Australia - Munich Motorcycles - I had them today with them arriving overnight - great bike shop and highly recommended
So 2 more pics -
« Last Edit: January 17, 2021, 11:23:33 AM by Justin B. »
1984 R65 (860)
Offline wilcom
« Reply #114 on: February 01, 2017, 12:27:44 PM »
Looking good, Adrian!!!
« Last Edit: January 17, 2021, 11:23:47 AM by Justin B. »
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline Adrian
« Reply #115 on: February 01, 2017, 05:50:01 PM »
Thanks Wilcom  ;)
1984 R65 (860)
Offline Adrian
« Reply #116 on: February 02, 2017, 02:06:30 AM »
I made my own Zinc Plating kit from info I found on the net. This is my test bolt to see how it all goes. Not a bad result considering this was a fully rusted up bolt. Not the brightest star in the night sky but acceptable.
So some wire brushing and then a clean in Isopropyl Alcohol and here it is after two 30 minute sessions. Not bad .....
By the way I did buy a replacement fasteners kit for the bike but some of the fasteners etc aren't included.
The green looking liquid is acid mixed about 75% to 25% water.
« Last Edit: January 17, 2021, 11:26:40 AM by Justin B. »
1984 R65 (860)
Offline skippyc
« Reply #117 on: February 02, 2017, 10:25:43 PM »
Hi What electrolyte did you use? They look alright.
Offline Adrian
« Reply #118 on: February 03, 2017, 02:14:36 AM »
Hi Skippyc - the electrolyte is made from 6 liters of white vinegar - 1 kilo of white sugar and 1 kilo of sea salt.
the zinc rods are plain ol' zinc anodes that can be bought from any decent boating shop. They are usually 99% or better zinc so they make excellent anodes.
Once the salt and sugar have been dissolved in the vinegar put the  anodes ( I use 4 - that's two zinc anodes cut in half) put the anodes in to the liquid for about 12 hours before using.
It works really well ......
1984 R65 (860)
« Reply #119 on: February 03, 2017, 04:28:41 PM »
Nice job Adrian,
She is going to look very nice[ch128077]
