Author Topic: Ongoing R100RT - R100T - R100RT Project  (Read 31213 times)
« on: August 12, 2017, 09:10:54 PM »
Years ago, probably 12 or so, I picked up a poor neglected '81 R100RT off fleabay.  I already had a '95 R100RT so I decided to make it into a nekkid summer bike - in essence an R100T.
After stripping it down I rode it for a summer (commuting) with one cylinder at about 50 psi compression on one cylinder and 110 psi on the other (straining to remember exact numbers...) but it actually ran OK for a commuter.
« Last Edit: January 17, 2021, 03:50:00 PM by Justin B. »
Re: Ongoing R100RT - R100T - R100RT Project
« Reply #1 on: August 12, 2017, 09:17:53 PM »
Once I had the engine up to snuff I decided it was a keeper so I had to make it not quite so embarrassing to ride so I cleaned up the frame and gave it a nice jet-black paint job.  I'd never owned a black motorcycle before so it seemed like  a good thing to do.
Those of you with an eagle-eye will note that I adapted a monoshock rear cowl and seat to the dual-shock.  I was then able to use the monoshock BMW Comfort Seat.
« Last Edit: January 17, 2021, 03:52:41 PM by Justin B. »
« Reply #2 on: August 12, 2017, 09:36:03 PM »
Alas, I let the '95 RT go after buying an R1150RTP and immediately started kicking myself for dabbling with the "dark-side" and yearned for my R100RT!
Late last year I decided that I would dig the busted up fairing bits out of the attic and properly clothe it once again as an R100RT!  I had to buy the two lower panels and lower center panel but was able to get out the fiberglass and save everything else.  About a month ago I got most of the "bodywork" finished and squirted on a coat of high-build primer.  After sanding that down I realized there were a lot of little nicks and stuff I missed but I figured I could nit-pick it to death and have it finished right before I wound up in an old-folks home.  After seeing the stunning contrast Marc Miller achieved on his R65 re-paint I decided that I would paint the fairing satin black which would give a stealthy look and also make the imperfections a bit easier to overlook.
I squirted the black on Thursday and started putting it back together yesterday.  I was really happy that I bagged up most of the original hardware in a somewhat logical manner and only lost a few screws.  I ordered a new "dash" (old one has some cracks) and windshield rubber from Max and as soon as it gets here I can finish assembling the upper fairing.  The shocking thing is that the clock and voltmeter work like a champ!  I never even tested these before tearing it down as I wasn't going to use them.
Here's as far as I got today...
« Last Edit: January 17, 2021, 03:56:07 PM by Justin B. »
« Reply #3 on: August 12, 2017, 09:41:03 PM »
Great job Justin. I wish I had the time and space to do the same.
Offline Adrian
  • The Old Hairy Biker Sez...
« Reply #4 on: August 13, 2017, 01:01:07 AM »
Nice looking bike mate - thanks for the photos :-)
1984 R65 (860)
Offline BPT
« Reply #5 on: August 13, 2017, 02:57:12 PM »
Nice job.
 From the time I bought mine, I wanted it to be black and was really leaning towards satin.  I decided I'd better get the running things taken care of before the cosmetics, but it's still on my mind every time I ride it.
What kind of set-up do you have as far as a paint gun?  A while ago, Montmil posted about his DIY paint job and made it sound doable, with some patience.
Do you have a lot of experience and/or proper equipment?
« Reply #6 on: August 13, 2017, 07:14:56 PM »
I have a nice set of DeVilbiss HVLP guns but I shot this with an old Harbor Freight HVLP.
I have painted for a long time although not so much in the past 10 years or so.
The fairing was painted with DuPont Hot Hues "Hot Rod Black."
Offline BPT
« Reply #7 on: August 13, 2017, 08:57:07 PM »
Ah, ok. So you do have some background and skills then.  I may give it a try. Haven't decided yet but budgetary reasons might lead me on that direction.
Anyway, nice job on that.  Good luck on getting it all sorted out.
« Reply #8 on: August 13, 2017, 10:03:33 PM »
It'll be back together by the end of the week, as soon as my hardware order from McMaster gets here...
« Reply #9 on: August 20, 2017, 01:47:17 PM »
OK, almost there!  I got everything back together (that I could find), changed the oil and filter, and flushed the front and rear brakes yesterday afternoon and took it for a spin.  Went about 4 blocks then cam back and tightened a few things I forgot!  After tightening these few things went for a couple mile ride this morning and all seems great except I think I have the steering head bearings a hair tight.  It handles a bit sluggish at low speed and has a low speed "weave" unless I am really paying attention.  I really hate messing with this now that the fairing is on and I'm hoping maybe after a little riding it will loosen up a bit but I'm not going to hold my breath.  I'm still missing a couple of little bits (L/H side air intake vent mainly) but it can be ridden.  I'd forgotten how loud the engine sounds on an RT!
This is my second R100RT and I still think the design is still about the best looking motorcycle ever made.  I am going to call this "Stealth RT" as the satin black fairing gives it a bit of a sinister look.  Here's thanks to Marc for his paint scheme or I would never have thought of painting it satin!
« Last Edit: January 17, 2021, 03:59:30 PM by Justin B. »
Offline wilcom
« Reply #10 on: August 20, 2017, 02:44:33 PM »
Justin............ Lamont has some RT fairing pieces on his site if you lost anything.....
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline BPT
« Reply #11 on: August 20, 2017, 03:52:57 PM »
Sweet!  Looks great, and I like the Stealth idea.
« Reply #12 on: August 20, 2017, 04:05:33 PM »
Thanks, BPT, I was going to paint it gloss black to match the rest but seeing how nice the satin came out on marcmiller's R65 I decided it would look wicked!
The only fairing piece I don't have is the L/H side air intake vent and I have one coming from fleabay.  When I bought the bike there was considerable "body damage" on the R/H side and I think I remember the vent being gone so I snagged one off fleabay.  When I went to paint them realized I "snagged" the wrong one so I wound up with two R/H ones!
Offline BPT
« Reply #13 on: August 20, 2017, 05:05:36 PM »
Since I bought my bike I'd wanted it to be black. I wasn't sure what type but, like yours, figured it would be the shiny version.  Shortly after I got it I saw a car that had been done in the satin. It was a nice job, not the usual crappy looking flat black you see (or whatever that is that they use for the pseudo-carbon fiber hood look?).
I went to English paints and they showed me a version that looked pretty close to what I'd seen, can't remember what they called it.  But I put off changing the paint for a while.
When I saw Marc's I thought "Yes, that's exactly what I'd pictured, and damn that looks nice!".
But now I've waited so long I'll just be a follower in the crowd.... :'(
« Reply #14 on: August 20, 2017, 05:14:11 PM »
The "Hot Rod Black" I used was for the side covers on an R100S for a dude a number of years ago.  I only used a couple of ounces and I had a bunch left over so that was another big point in it's favor!
« Last Edit: January 17, 2021, 04:02:13 PM by Justin B. »
