Author Topic: R100  (Read 11730 times)
Re: R100
« Reply #15 on: March 10, 2014, 06:23:51 AM »
Actually, I am calling a halt to this for the time being.  There are too many changes that I am having to carry out.  I need to get my ducks properly lined up.  And do a bit more preparatory work done.
I need to source another set of headlight ears, that can be modified to take the R100 headlight with ignition.  Or move the ignition.
I need to find another place to mount the indicators - which I want to change anyway.
I need to extend the wiring for the new handlebars.
I need to sort out how to mount the instruments.
I need to polish up the top and bottom yokes before I fit them.
Did I mention that it was sunny this weekend for the first time this year - with temps above 18 deg Celcius.  And my bike was in bits all over the garage floor.  Hurumph!
I will get back to this......In a month or two.
Rev Light
« Last Edit: March 10, 2014, 09:01:21 AM by steve_hawkins »
Re: R100
« Reply #16 on: March 18, 2014, 06:00:57 AM »
Bike is back together with wiring extended for the new wider handlebars.
Extending the wiring was a bot of a chore, especially when it came to reconnecting them inside the headlight.  The current (white hardback)Haynes Manual only shows the American wiring diagram for post 81 R100.  So I had trouble getting the headlight switching working again.  Fortunately my brother had a copy of the earlier (green softback) version which showed the correct wiring...mostly.
I had quite a few issues with the forks, or at least securing them to the top toke.  They were not correct, and I had two top washers missing.
I am enjoying the new riding experience.
Nose fairing now removed.
Time to remove the bearings and get the R65 yokes polished up.
I am considering moving the ignition from the headlight, so I can use my favorite alloy headlight ears.  lots of things to get sorted.
Rev. light
« Last Edit: March 18, 2014, 06:01:51 AM by steve_hawkins »
Re: R100
« Reply #17 on: March 18, 2014, 08:27:15 AM »
Actually,
Looking at Monte's headlight ears, I wonder if you could enlarge the middle hole and cut off the end one.  It looks like the head light is mounted further 'out' than standard.  I wonder if it would take a 25mm hole.......
Re: R100
« Reply #18 on: June 02, 2014, 02:17:50 AM »
We are still soldiering on with this project.
I have now sorted the headlight ears and fitted different Indicators on them.  Thanks for the idea Monte.
I have fitted a shorter seat and sub-frame, along with alloy mudguards/fenders, along with new lighting.
Still at the dry build stage - i.e. trying thing out till I get the look that I am after.
Here's a picture.
Rev Light
Re: R100
« Reply #19 on: June 02, 2014, 09:33:37 AM »
Looks good Steve !
I think that you've got the headlight positioned pretty nicely.
Can you show a closer-up pic of the handlebar/top brace area?   I may have to make some mods to my R100 sidecar rig and am trolling about for different ideas..
Re: R100
« Reply #20 on: June 02, 2014, 09:55:18 AM »
The top brace is still R100 steel plate, currently.  I have been doing all the jobs around it to ensure that if and when I make the change to an R65 set of yokes, it will be a quick swap out and not a week's work - having done the week's work prior...... ;)
Something about lining all me ducks up....
Rev Light
Re: R100
« Reply #21 on: June 09, 2014, 03:02:10 AM »
Just removed the knee pads on the tank.
I am in the process of making good the paint, as it was blue underneath!
The knee pads were an absolute sod to get off.
A few more coats of paint and I should be able to flat it all back and loads it completely.
Tank looks like a boiled sweet now!
Rev Light
Re: R100
« Reply #22 on: June 24, 2014, 01:23:08 PM »
here goes another picture or two
arvo92
Re: R100
« Reply #23 on: June 24, 2014, 03:36:28 PM »
I do like the indicators. They are pretty classic but a bit trendier with a chrome back. My Iž Jupiter 4 has similar ones but with plastic back.
Re: R100
« Reply #24 on: June 25, 2014, 02:07:44 AM »
They are Lucas 'knock-offs' like you would fit to a Brit bike of the 70's.
I preferred them the rectangle BMW ones.  Its a styling exercise.
Rev Light
Offline jamestnewsonr65
Re: R100
« Reply #25 on: June 25, 2014, 07:36:06 AM »
Steve, where did you get your seat from?
The shorter rear frame on yours looks exactly the same as what I have done to my rear subframe.
I did buy 2m of recycled leather which looks great, with the possibility of creating my own seat. But it's not waterproof and buying one seems easier when you have a thousand jobs to do already.
The bike looks great, and thanks for the brake pics.
1981 R65 (box of bits).
Re: R100
« Reply #26 on: June 25, 2014, 09:45:12 AM »
The seat is from a firm called Vonzeti, from down Devon way.
Not sure they do an R65 specific one.
They are also very expensive.  It was a treat to myself.  You could do it cheaper if you had a local specialist cover the saddle for you.
They are made to order and can take weeks longer than the 21 days they normally quote....Don't ask me how I know :-?
Yes, leather is not waterproof, you would be better off with vinyl.  But it depends on what you are using the bike for.
It is important to get it right.
Rev Light
