Author Topic: CaptainSlow's R65 log  (Read 13713 times)
CaptainSlow
« on: February 14, 2013, 11:58:04 AM »
Well today was the first day that I managed to get any time to look over my new acquisition - the 1983 R65LS previously called the Red Tomato owned by beemer. We haven't come up with a new name yet, but something suitable will be found soon..
Anyway, I've spent about 6 hours on the paintwork today. She was a bit faded, somewhere between pink and orange in places rather than bright red. So I washed it, T-Cut it, then used Dodo Juice paint cleaner, followed by 2 coats of coloured wax and another 2 coats of carnuba wax. It took a while as I've been disassembling bits to get them clean - even removed the grab handles lol. The result...
Yes she really is that shiny  :) I've taken the two side panels off as they were horribly pitted, so I've sanded them nice and smooth and am currently repainting them black - as luck would have it I have a couple of cans of primer and black paint handy. Two coats of primer, and one coat of black done so far. Not sure how it'll take as its a damp 5 degrees here  :-/ It'll either work or it won't!
On the downside, I've found an oil leak - she's pee'd while she's been parked up, so I'll have to take a look at that before going for the MoT. She fires up on the button and runs nicely, all lights work fine, so I'm hoping that she'll go straight through. Might change the brake lines first though - not sure if/when they were changed and I'd rather not trust 30 year old rubber brake lines when I'll be doing 12000+ miles a year on her. I'll change the fluid and put ATE Super Racing Blue brake fluid in - I've been using this stuff for years in my cars and bikes and love the stuff. Anyway, that'll be featured in a later update no doubt...
Thanks for reading, I know I go on a bit lol
Re: CaptainSlow's R65 log
« Reply #1 on: February 14, 2013, 02:36:09 PM »
Hi Sam,
She looks very nice!
Whereabouts in Yorkshire are you? I am in Honley 4 miles from Huddersfield.
I am in the process of restoring an 81 R65, it's slow for various reasons, but I hope to be back on the road by the summer!
Chris
Offline Dave 2
« Reply #2 on: February 14, 2013, 04:04:35 PM »
That is one very nice looking bike, You should be real happy with it.D2
CaptainSlow
« Reply #3 on: February 15, 2013, 03:17:54 AM »
Thanks! To be honest she desperately needs a respray, the photos don't show all the scratches which have been touched up in different shades of red. The wheels are a creamy yellow and chipped in several places etc. But she is exactly what I expected for the money, so yes I'm very happy.
I'll run her for a year to identify any problems and get used to her, then I'd probably strip her down and do a full rebuild next year - for a 30 year old she is in far better condition that any 30 year car I've seen! The frame has some cosmetic rust, nothing serious found so far, and the condition of the oily bits seems to confirm the low 29k mileage. Beemer looked after her well.
I've got some crash bars and period panniers to go on - the pannier frames are from an R100RS so need 'adjustment' as the rear cross brace hits the rear lamp. So I need to modify that or else get a proper R65 frame set - depends what pops up at the right price in the next few weeks.
MR.E
« Reply #4 on: February 16, 2013, 04:07:43 AM »
Sam
Looking nice, it looks so shiny a Ferrari badge wouldn't go a-miss on the front mudguard!!
I've quite a gathering of parts (inc wheels) if you need anything feel free to ask.
Elliott
CaptainSlow
« Reply #5 on: February 18, 2013, 10:57:07 AM »
Thanks Elliot  :) As it happens... I don't suppose you have some R65 luggage frames do you? The R100 ones that came with the panniers I bought are too long. I could butcher them but I'd rather get the correct ones to be honest.
Cheers, Sam
MR.E
« Reply #6 on: February 19, 2013, 02:16:01 PM »
Sam
I don't actually, I got rid of mine but kind of wish I hadn't!!
They pop up on eBay often for around £50
CaptainSlow
« Reply #7 on: February 20, 2013, 12:55:34 AM »
OK, thanks anyway  :)
CaptainSlow
« Reply #8 on: March 18, 2013, 07:15:52 AM »
Well I was measuring the size of the carbs to see if they'd fit into an ultrasonic cleaner that I was considering buying, when I noticed a few crushed wires that will need some attention. A further few minutes of inspection revealed the fuel tank overflow pipe being routed to deposit any excess petrol over the left exhaust pipe  :o And then I glanced at my rear wheel and saw this -
Now the wheel has obviously been subject to a quick n nasty repaint (not sure if its housepaint or from a spraycan to be honest) but the surface has cracked all the way around the rim on both sides of the wheel  :-? I've heard of the rear wheel getting quite hot due to the heat of the shaft drive being transferred to it, but would this heating/cooling cycle be enough to cause this kind of crack? I'm just hoping that the rear wheel isn't FUBAR'd ! At the moment I can't tell if the crack is in the wheel itself, or is just the paint. I'm going to get some paint stripper later to see what is hiding under that creamy nastiness...
This bike is rapidly descending from a nice, original R65LS to a moderately extensive overhaul project!   ::)
« Last Edit: March 18, 2013, 07:18:14 AM by CaptainSlow »
CaptainSlow
« Reply #9 on: March 19, 2013, 07:25:52 AM »
Gota love eBay sometimes - got a large ex-dental ultrasonic cleaner now - the tank is roughly 240mm x 140mm x 150mm deep, so it'll take the carb bodies fully submerged. That means I can strip them down and get them uber clean, inside and out.
Also managed to be the only bidder on a K75C handlebar, so I won that for the opening bid [smiley=thumbsup.gif]
Still a bit concerned about the wheel, but I won't get time to look at it again until the weekend... I'm crossing fingers, toes etc etc that it is just the paint that has cracked.
I've had a few quotes in to get both wheels prepped and powder coated glossy black, and one of them also does anodising, so I'll probably get those handlebars anodised black while I'm there...
Yes, I've decided she's a project not a running rebuild, so I'm getting a game plan together, and she won't look like an LS afterwards sorry. I'm going old skool black, white & chrome  [smiley=thumbsup.gif]
« Last Edit: March 19, 2013, 07:27:05 AM by CaptainSlow »
CaptainSlow
« Reply #10 on: March 22, 2013, 04:40:35 AM »
Found these pics on the web - a combination of these is what I'm hoping my R65 will look like... eventually !
What do you think?
« Last Edit: March 22, 2013, 06:11:36 AM by CaptainSlow »
MR.E
« Reply #11 on: March 22, 2013, 07:34:10 AM »
they look nice, but i'm not a fan of the snowflake wheels!
you going cafe style with the rear pod?
CaptainSlow
« Reply #12 on: March 22, 2013, 08:32:41 AM »
Probably more along the lines of the second pic Mr.E.
If I change the tank to a sculpted one, I have to think about where the electrical gubbins are going to go - I want to keep the airbox as I'll be riding in all weathers, so open air K&Ns probably aren't a good idea. So I need a bit of room for the relays etc, or possibly a gel battery (with the relays in a custom box on the battery tray). All fluid ideas at the moment, the only constraints are money (as always!), time (ditto), and keeping the wife sweet... ;)
« Reply #13 on: March 22, 2013, 09:04:57 AM »
We will all look forward to reading about your fitting of a disc brake on the rear wheel -if that's part of your plan. As you mentioned, Cap'n, it's always the money... and time. Plus the money. [smiley=happy.gif]
CaptainSlow
« Reply #14 on: March 23, 2013, 03:08:09 AM »
lol, no I think the rear disc is a step too far at this stage montmil  ;D While I'm sure its do-able (everything is, given time and money) I think I'll just stick with the rear drum for now.
One quick question if I may - am I right in assuming that the airhead monoshock tanks will fit the R65 without the need to rejig the electrics? As you've probably noticed, I'm discounting the toaster tank straight off as the chances of finding one of those at an affordable price are zilch!
« Last Edit: March 23, 2013, 03:09:57 AM by CaptainSlow »
