Author Topic: Auto Coolant Additive  (Read 2744 times)
« on: August 03, 2013, 09:44:37 AM »
I've had my '91 Honda CRX Si 22 years this week .
I've had the worst experience with failing water pumps on this vehicle than any other water cooled car I've had, they usually fail around 3 years, with coolant leaking out of the 'weep' hole in the water pump casting .
About 5 years ago I learned of a product, Water Wetter, the manufacturer claims it reduces operating temperature by modifying the cohesion characteristics of water on the metal of the engine.
You use 1 fluid ounce of additive, per quart of cooling system capacity .
It also has a lubricant of some sort in it for the water pump .
My current water pump is going on 6 years now, no leaks so far .
Can't say I see any difference as far as operating temperature goes, but it seems to have cured the early failure of the water pump .
I get it locally for around $10US for a 12 fluid ounce bottle .
I change the coolant every three years .
http://www.redlineoil.com/Products.aspx?pcid=10
« Last Edit: August 03, 2013, 09:50:45 AM by Bob_Roller »
Re: Auto Coolant Additive
« Reply #1 on: August 03, 2013, 01:56:39 PM »
As so many newer motorcycles are "wet", I'm seeing ads for "water wetter" products in most all the bike mags. Perhaps my water-pumper Triumph Triple might benefit from a small dose.
FLAPS sometimes refers to them as a water pump lubricant. Maybe keeps the seals flexible for a longer time period.
Stuff must work. Like, they couldn't run those ads if it wasn't true... right? :)
« Last Edit: August 03, 2013, 01:57:35 PM by montmil »
« Reply #2 on: August 10, 2013, 09:51:51 PM »
I believe that those products are not welcome at official racetracks, as, in the event of a crash and spillage, the stuff is really very slippery and doesn't dry up quickly.
I've thought about trying it in my Kawasaki Concours, but I've been a bit scared to as it has been rock solid-reliable for 15 years now, and I just use the Kawasaki coolant and distilled water in it.
