Author Topic: Rusty motorcycle bits n' lawnmowers  (Read 2393 times)
« on: January 29, 2012, 02:18:11 PM »
Loosening rusted threaded components has been periodically discussed in the R65 Asylum. What else is there to do when Nurse Ratched is close by?
Several members, myownself included, swear by a 50/50 mix of automatic transmission fluid, ATF, and acetone. Soak the rusted nuts and wait awhile; they usually come away. This witch's brew has again saved the day for me... or at least saved my lawn mowing day.
Vibration took its toll on the 21-inch B&S 158cc hot rod's muffler. Split it half way 'round the perimeter. Noisy. A slip-joint, toothed oil filter wrench twisted off the sheet metal but left a flanged 1/2-inch pipe thread muffler stub rusted into the crankcase (it's a side-valve engine).
Took an hour for the ATF/acetone mixture to do its thing. A pair of waterpump pliers spun out the pipe. Some anti-seize compound and I'm good to go.
Yes, it's January 29th, sunny and 63[size=14][ch730][/size]F... and I need to mow the yard. The usual McFarland Signature, a weather pattern that brings what passes for cold winter temps in Texas, is staying well north of us.
I'm mowing this afternoon. Monday and Tuesday are forecasted 69-70F and sunny. I'm riding both days.
[smiley=clap.gif] I still hate yard work...
« Last Edit: January 29, 2012, 02:39:06 PM by montmil »
Re: Rusty motorcycle bits n' lawnmowers
« Reply #1 on: February 04, 2012, 08:29:17 AM »
Wow, that's some nasty stuff you mixed up there buddy.  Hope you wear acid resistant gloves and a ventilator when you use it.  As for the yard work, I have to agree with you, my motto is "You can't improve on nature."  Good thing Mrs. Phorqs loves to commune with all things vegatative.
« Reply #2 on: February 04, 2012, 08:30:45 AM »
...and I forgot to ask, when did you get together with Louis Fletcher for that photo?  Were you an extra in the movie "One Flew Over The Cuckoo's Nest"?
« Reply #3 on: February 04, 2012, 08:43:20 AM »
You funny, Phorqs.
Mongo  [smiley=mad.gif]
« Last Edit: February 04, 2012, 08:43:54 AM by montmil »
