Author Topic: Tyre comments  (Read 9641 times)
Re: Tyre comments
« Reply #15 on: January 29, 2017, 05:20:26 PM »
90/90-18 front, 120/90-18 rear. This is an '86 R-65 with the single sided swingarm and I have about 3/8" clearance between the tire and arm.
Ah! Mine's an 84 so I can't fit "big' width tyres.
Re: Tyre comments
« Reply #16 on: January 29, 2017, 07:15:10 PM »
There is a difference in swingarm clearance on the monolevers versus the twinshock as far as tires go, but I haven't owned both types of airheads at the same time to give a good numerical analysis.
Offline DonC
Re: Tyre comments
« Reply #17 on: January 31, 2017, 09:17:01 AM »
Tony,
For what it's worth I just measured the mounted rear tire and it measures 4 9/16" or 117mm at its widest point. That's at 33.5psi or 2.3bar where I run the rear pressure.
Stock rims MTH 2.50 x 18E...whatever that means??
Re: Tyre comments
« Reply #18 on: January 31, 2017, 11:20:16 AM »
117mm isn't so bad.
That would just about fit in my early model twin shock and the early ones I think are least accommodating.
« Last Edit: January 31, 2017, 11:20:46 AM by bhodgson »
Re: Tyre comments - tyres ordered.
« Reply #19 on: February 01, 2017, 04:50:18 AM »
I've ordered my new tyres.
Pirelli sport demons - 100/90 front and 110/90 rear.
Offline DonC
Re: Tyre comments
« Reply #20 on: February 01, 2017, 08:29:04 AM »
Pirelli...good tires! Let us know how they work out.
Re: Tyre comments
« Reply #21 on: February 02, 2017, 04:57:04 AM »
Will do - I am currently running Pirelli city Demons but they no longer make a 4:00-18 rear or any metric equivalent.
Offline Matt Chapter
  • <insert witty remark here>
Re: Tyre comments
« Reply #22 on: February 03, 2017, 03:06:38 PM »
I got super excited and went to look... Pirelli doesn't offer a 90/90 18 size.  They have the 120 / 90 I'd prefer to run on my monoshock but even though I rarely have matched tire wear I occasionally like to have the same model on the front and back.  The one time I tried a 100/90 in the front I disliked how it changed the steering.  Luckily my front tire is practically new.
'04 R1150 RT ~41000 miles
Offline drewsonofdean
Re: Tyre comments
« Reply #23 on: October 19, 2017, 10:44:52 PM »
I got some Bridgestone Spitfire's, pretty good so far!!
Re: Tyre comments
« Reply #24 on: October 19, 2017, 10:45:27 PM »
And they are on special at jakewilson.com
Offline tunnelrider
Re: Tyre comments
« Reply #25 on: December 30, 2017, 12:49:22 AM »
I'm running Ribaldi Wild Horse on/off road tyres, 4.10 rear for my twinshock, 3.50 front.  They're made in Brazil, on my 2nd set after going through two sets of expensive Metzelers too quickly and trying Dunlop Arrowmax, which I was quite happy with but severely shortened the life of the rear doing a couple of burnouts :-[ :-[
I'm impressed with the Ribaldi's stickyness once they're warm and the first set I had the rear lasted 9K km.  Another good thing is they cost only $80NZ each, about $73 Aus dollars. Being semi knobblys (with road bias) they are noisy on smooth roads though.  I ride the poor thing reasonably hard and the Ribaldi's stick well.
Re: Tyre comments
« Reply #26 on: January 04, 2018, 07:24:13 PM »
I bought Shinko tyres front and rear - thanks to all those who commented favorably on the brand.
The front is now fitted to the K100 front wheel that will be going onto the R65, the rear is waiting for the LS rear wheel, axle and spacer I've bought to arrive - this is a cunning plot on my part to keep it all looking OEM, the K-bike front pattern looks identical to the LS pattern unless you look very closely. I got the wheel for cheap as it has a pretty big flat spot in it, however a local business has looked at the photos and reckons they can roll it out.
If they cannot I will be tempted to fit an R80 subframe and the R80 monolever I have in stock.
Re: Tyre comments
« Reply #27 on: January 22, 2018, 11:42:04 AM »
I can't find Ribaldi Wild Horse tires on Google, is that worded right?  I just wanted to see what they looked like.  I bought some Dunlop K70s for my Triumph, they look like they'll be good at least for gravel roads.  Not available in an 18" front though.
Offline tunnelrider
Re: Tyre comments
« Reply #28 on: February 08, 2018, 02:57:03 AM »
I just had a search Ed and (ahem) you're right, I got the spelling wrong sorry.  Rinaldi WH21, available in 18 inch front and back.  I've got a 2.75 front (70mm, narrow!) and 4.10 rear (104mm).  Still I haven't found them much different riding corners, perhaps the bike tends to dive in to the corner a bit quicker.
http://www.cycletreads.co.nz/products/633-rinaldi_trail/6478-rinaldi_wh21_trail_tyre.aspx
Re: Tyre comments
« Reply #29 on: February 15, 2018, 03:25:08 PM »
This page lists a 90-90/18 but says it's not available right now.  They look like an interesting tread pattern.
https://www.varellamotos.com.br/pneus-para-motos/off-road/rinaldi-wh21/m?dep=000001&art=000015&sessao=000032
