Author Topic: Another use for dielectric grease  (Read 2432 times)
« on: October 07, 2013, 07:42:35 PM »
Got up the other day to find that a rear caliper was seized on the NA Miata.  A few weeks back the front had gotten sticky as well...
as best I can tell, the problem (with both) was that the sliding caliper was not sliding on it's guide pins.  After cleaning up the rear pins today, I applied dielectric grease to them... it is essentially a waterproof silicone grease, and if it can take the heat at a spark plug boot atop an engine, I figure it should be able to take the heat at a caliper pin as well.  Supposedly Ford sells a tube of the stuff as dielectric/brake caliper grease.
So if you are ever in a pinch or don't want a container of brake grease that gets used once a year (if that), give the stuff a shot.
Re: Another use for dielectric grease
« Reply #1 on: October 07, 2013, 08:32:53 PM »
Silicone Plumbers Grease is pretty much the same thing. Available in small quantities at hardware and Big Box home improvement stores.
« Reply #2 on: October 07, 2013, 08:53:15 PM »
It is pretty good stuff, but I have found that it will freeze - at least, it can when it is in a terminal block connection on the front of a plow truck when you are plowing a snow covered road in -20F temperatures.
« Reply #3 on: October 08, 2013, 10:23:08 AM »
That's just pitiful. [smiley=lolk.gif]
« Reply #4 on: October 08, 2013, 12:14:32 PM »
-20F ? I don't think even my freezer gets that cold. My winter is when I change from flip-flops to sneakers.  8-)
« Reply #5 on: October 08, 2013, 03:02:33 PM »
Mike, Your "frozen dielectric grease" comments remind me of a few Peter Egan writings -Cycle World columnist and others- where he talks about the ice and frozen snow that keeps him from opening his shop door... all winter!
Terribly short riding season for you guys.  :'(
Bob_W
« Reply #6 on: October 08, 2013, 03:51:22 PM »
Marc
It is winter up north here in McIntosh County. Just put on a long sleeve shirt. About 65 and the wind is blowing.
Bob
« Reply #7 on: October 09, 2013, 08:20:30 AM »
That all depends on how low you can go
I get pretty uncomfortable by 40F, but I'm hopeful that putting some handguards on will help things improve.  Would be nice to have some heated gear...
« Reply #8 on: October 10, 2013, 11:51:26 AM »
I will usually ride into November, but the trips become much less frequent and shorter duration.
