Author Topic: Swingarm locknuts  (Read 864 times)
Offline BooG
Swingarm locknuts
« on: September 29, 2008, 04:10:20 PM »
Just finished an 11 hour session!! Pushrod tubes sorted..heads and pistons de-coked..have turned my attention back to the driveshaft gator, but I can't seem to loosen the locknuts. They are not having it. I've asked them nicely with gentle hammer strokes on the box spanner, and with heat, but no joy! I'm thinking that I will have to do the 27mm socket ground down, with an extension bar to help loosen them. Is this usual? Any tips welcomed as usual.
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Crossrodes
Re: Swingarm locknuts
« Reply #1 on: September 29, 2008, 04:42:02 PM »
I just finished adjusting and tightening mine and they are supposed to be torqued down well (105 Newton Meters).  So they are probably too tight for a mere spanner.  You will need a socket and a long (12-18") breaker bar or ratchet
Offline BooG
« Reply #2 on: September 29, 2008, 04:51:31 PM »
Thought as much!!
Thanks for the shout. I'll do it in the morning.
I'm off to watch the collapse of capitalism on the news!
BMW R65 1980.
BMW K75S 1987
« Reply #3 on: September 29, 2008, 05:36:37 PM »
My Lock nut socket is a Great Neck 1-1/16" half inch drive SK59.  No grinding required!!!
