Author Topic: Front Rotors  (Read 1075 times)
mimmo66
Front Rotors
« on: August 30, 2010, 07:45:37 PM »
Has anyone tried these rotors yet?
http://www.wemoto.com/bikes/BMW/R_65_Double_disc_model/81-85/picture/Disc_Front_Kyoto/
It seems a good price. All you have to do is pop old rotors out and install new ones in with those rivets I think.
Just looking at some alternatives pricewise.
Thank you,
Domenico
« Last Edit: August 30, 2010, 07:47:26 PM by mimmo66 »
Re: Front Rotors
« Reply #1 on: August 30, 2010, 09:31:42 PM »
I would check with the seller and see if the carrier or hub needs to be machined to accomplish this modification .
I had Spiegler Performance perform  their semi-floating conversion to the front rotors on my '84 LS .
They had to do some machining to make the parts fit the hub, or carrier .
http://spieglerusa.com/BMWConversions/
« Last Edit: August 30, 2010, 09:33:43 PM by Bob_Roller »
Re: Front Rotors
« Reply #2 on: September 07, 2010, 03:24:57 PM »
I'm also planning to go this route although I have more options now that I have the K100RS front end on th ebike.
