Author Topic: Haynes manual translations  (Read 1020 times)
« on: January 31, 2008, 01:06:08 PM »
I've never seen this list before, swiped it from a post in Volvo forum I haunt but I suppose we could apply it to the motorcycle manuals as well...
HAYNES CAR REPAIR MANUAL - A TRANSLATION
Haynes: Rotate anticlockwise.
Translation: Clamp with vicegrips, then beat repeatedly with a hammer
anticlockwise.
Haynes: This is a snug fit.
Translation: You WILL skin your knuckles.
Haynes: This is a tight fit.
Translation: Not a hope in Hell, matey!
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start, now you
are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Try lots of heat, a tin of WD40 (catering size), or a ten
pound hammer.
Haynes: Retain tiny spring...
Translation: "Jeez! What was that? It nearly had my eye out!"
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers to
dig out that pesky bayonet part.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your forehead
are throbbing, then re-check the manual because what you are doing now cannot
be defined as 'lightly'.
Haynes: Weekly checks...
Translation: If it ain't broke, don't fix it!
Haynes: Routine maintenance...
Translation: If it ain't broke... it's about to be!
Haynes: One spanner rating.
Translation: Your Mum could do this, so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a low,
tiny, little number... but you also thought the wiring diagram was a map of
the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
Translation: But Bricks are easy to maintain right, right? So you think three
spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you amateur!
Haynes: Five spanner rating.
Translation: OK - but don't expect us to ride in it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
Translation: Hahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear at,
throw at the garage wall, then search in the dark corner of the garage for
it whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are looking
at, then declare in a loud knowing voice to your wife "Yep, as I thought,
it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Adjust gap to specified distance.
Translation: Ha-ha - got you again - you can search this book forever and
you won't find it!
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark plugs removed.
Translation: However, starting the engine afterwards will be much harder.
Once that sinking pit of your stomach feeling has subsided, you can start to
feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Pry away plastic locating pegs ...
Translation: Snap off ...
Haynes: Using a suitable drift ...
Translation: The biggest nail in your tool box.
Haynes: Everyday toolkit
Translation: Ensure you have an AAA Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: The bearing inner races can be released by applying light leverage.
Translation: There is absolutely no way those inner races will budge without
the application of a puller (which you haven't got) and a lot of swearing.
airhead
Re: Haynes manual translations
« Reply #1 on: February 01, 2008, 03:12:23 AM »
Haynes; Dealer serviceable item.
Translation; We couldn't get it apart either!!
Haynes; ........all other models.
Translation; we couldn't be bothered listing them.
Haynes; Warning: It must be stressed the ignition system employs extremely high voltages.......
Translation; The apprentice is still in hospital.
Haynes; Warning: Do not use gasoline as a cleaning medium...
Translation; As above!!
Haynes; Remove engine from frame.
Translation; There may well be a few points we've skipped here, I went for lunch when it was done so just do your best.
Bill...............;-)
