Author Topic: Bag Racks for R65  (Read 1008 times)
Danno
Bag Racks for R65
« on: August 22, 2008, 09:08:46 AM »
I'm sure this topic has been discussed before but, what are the differences in the bag racks (pannier and top) for an R65 specifically a 1984. Can another mount be modified or is it too different?
Dan
Re: Bag Racks for R65
« Reply #1 on: August 22, 2008, 10:51:14 AM »
BMW had (2) mounting systems  (one that had separate left/right pieces just for supporting side panniers, and one
that was all of one piece that combined a small integral rear rack) for the R65/R45 models.  These would fit any
bike in the 80-84 range, but the R65LS, because of its wider rear seat cowling and passenger handles, could only use
the separate pieces model as the all-in-one unit  wouldn't clear the cowling.   Reynolds also sold 1 or 2 models with a swing-back
rear rack that would work on any of the "standard" R65 bikes, but not the LS.
The mounting systems for the bigger bikes R80/R100 are not the same and have slightly different dimensions due to the
taller/longer rear shocks for those frames,and also the front mounting point for them is rotated 90 degrees from that for the R65s.
If one is good with a hacksaw and welder, one of these could be modified to fit R65 bikes in a pinch.
Danno
« Reply #2 on: August 22, 2008, 11:06:12 AM »
So the 80-84 1 piece version would fit 84 non-LS? I've got to do something. I'm getting tired of using a backpack all the time. Sounds like a good Minnesota winter project.
Thanks, Dan
« Reply #3 on: August 22, 2008, 07:54:38 PM »
Or you could use some soft throw over panniers....
« Reply #4 on: August 23, 2008, 10:02:59 AM »
I've now got the BMW touring cases which leaves me with a set of these http://tinyurl.com/6o2hch
Used once. I need some boots so I'll let 'em go for a fair price.
I thought Minnesota winter projects involved Walleye and ice shacks :)
Danno
« Reply #5 on: August 23, 2008, 12:06:02 PM »
I sent you a PM. Let me know if you didn't get it.
Dan
