Author Topic: Head cleaning  (Read 2218 times)
Offline vtmando
Head cleaning
« on: May 04, 2016, 03:11:00 PM »
I know I've seen info before about cleaning oxidized heads and engine...I would like any suggestions for cleaning. Blasting with baking soda? Aloxide, Glass bead or should I stay away from pressure blasting totally.
Thanks!  :)
steve
1982 R65 ?
1973 R75/5
Re: Head cleaning
« Reply #1 on: May 04, 2016, 05:32:20 PM »
Are you wanting to clean the engine in situ or as disassembled components?
Re: Head cleaning
« Reply #2 on: May 05, 2016, 08:56:33 PM »
Welcome aboard!  Nice Toaster!
The problem with blasting is that some media can have the potential to create problems down the road if things aren't meticulously & thorough cleaned afterward - and this is with a disassembled engine.   An an assembled engine I think there are just too many places where stuff can get in and lodge and create issues from accelerating oxidation, to plugging oil galleries or vent holes.
If you're taking the cylinders/heads off and cleaning them separately, you could possibly go with soda or walnut shell media and just be 101% sure that everything is cleaned off.  Glass can work pretty well too and it doesn't have the disadvantage of oxidizing the alloy surface black if it isn't absolutely completely removed.   But you do have to make sure there aren't any beads hiding in nooks and crannies, and they won't dissolve with water.  I'd avoid any sand-type material as some of that stuff can really cut, and these alloys aren't that hard.
It is slow and time consuming, but when I decide the cases need cleaning, I get a big pack of  green (nonmetal) scouring pads, some WD40 and some brake cleaner, and go to work.    If you look hard enough, you can find some of the nonmetal scouring pad material sheets attached on a rotary drill attachment that can help quicken the task on the larger surface areas.
« Last Edit: May 05, 2016, 08:59:55 PM by nhmaf »
Offline vtmando
Re: Head cleaning
« Reply #3 on: May 08, 2016, 01:10:26 PM »
Thanks...! I may just go with the scouring pad and elbow grease!
1982 R65 ?
1973 R75/5
