Author Topic: electrex RR45  (Read 5633 times)
Offline guyom
electrex RR45
« on: January 20, 2016, 03:02:07 PM »
Hi Guys, i'm a new arrival in the R65 world. I bought a R65 1981, cheap, but not in good shape. When i checked the electrical cord, many are burn and modified from original position. So I changed everything, and install a M-unit. In a same time i need to change the regulator (and by the way) the diode board and replace them by a RR45 form Electrex. My question : i tempted to install the new RR at the place of the diode board but is there enough fresh air to cool down the RR or do i need to install it under the tank at the place of the old regulator... but looks more difficult to do something clean (need more space of the RR45 compared to the old stock). Anyway, if anyone has a suggestion...
Re: electrex RR45
« Reply #1 on: January 20, 2016, 04:14:17 PM »
Is this what you want to install for a voltage regulator http://www.wemoto.com/parts/picture/el-rr45/ Pricey rascal.
Motorrad Elektrik offers a solid state Voltage Regulator that is a direct replacement for the OEM unit. Plug and play all the way. No wiring changes or relocation needed. At $39.00USD it's far less expensive and a popular upgrade amongst the Airhead set. http://www.motoelekt.com/charging.htm
What is an M-unit?
Welcome to the forum. Before spending unnecessary cash and making unproven mods to your R65, check in to our asylum and voice your ideas and plans. We can offer ideas, suggestions and tall tales. Post a photo of your R65 when you can. We love photos of member's bikes.
Offline guyom
Re: electrex RR45
« Reply #2 on: January 21, 2016, 10:43:22 AM »
Hi thanks for reply.
The RR45 allows to remove diode board and regulator. My question was about the place to put it... i want at the place of the diode board under the front panel to hide it but i'm wondering about the air flow : sufficient or not to cool down ?
The M-unit is a digital control unit for your motorbike - the 'heart' of the vehicle's electrical system.
I just upgrade because all the wiring cord and relay are burned or modified with strange connexions... so two options : #1 buy a new old stock (wiring cord, relay regulator) or #2 a digital solid-state one and simplify the electric cord. I choose the #2.
Pictures of the bike will arrive soon. Thanks for time
Guyom
Re: electrex RR45
« Reply #3 on: January 21, 2016, 11:16:50 AM »
Do you have a link to the new part you installed ???
Seems like we don't have anything comparable to be able to give any advice on it .
www.electrexworld.co.uk/acatalog/RR45.html
The part looks like regulator/ rectifier that use Zener diodes, but I could be wrong .
With the cooling fins on the part, I would place it in an area that gets plenty of airflow, under the front cover of the engine doesn't appear a good place to install it  .
« Last Edit: January 21, 2016, 11:32:19 AM by Bob_Roller »
Offline guyom
Re: electrex RR45
« Reply #4 on: January 21, 2016, 12:19:07 PM »
Hi Bob, yes this is the part Electrex RR45 (www.electrexworld.co.uk/acatalog/RR45.html).
 Thanks for the advice. So I'm going to put it at the place of the Old stock regulator under the tank.
Guyom
Offline guyom
Re: electrex RR45
« Reply #6 on: January 21, 2016, 08:03:43 PM »
by the way here is the M-unit
http://motogadget.com/en/electrics/electronic-control-box-m-unit/m-unit/m-unit-digit-tastersteuerung-u-sicherung.html
That is a clever piece of technology, albeit at a big price Euros 270. If I was wiring a bike from scratch I would seriously consider one, but integrating it into an existing wiring loom would seem to be an entirely non-trivial task.
Also interested in your Electrixworld regulator/rectifier, It looks like a fairly generic device, very similar in fact to the Chinese one I have just fitted to the KLE at a cost of $AU 15.00 delivered. Did they supply a wiring diagram with it? The secondary reason I'm interested in Electrixworld's products is that I am about to order a new rotor for the KLE for them, mine is an early model with glued in magnets that have a reputation for coming adrift - the genuine Kawasaki later part with the stainless steel sleeve crimped over the magnets is more than the KLE currently owes me in total, hence Electrixworld's price of $AU250 for one looks attractive.
Offline guyom
Re: electrex RR45
« Reply #7 on: January 22, 2016, 02:02:23 PM »
HI tony, agree with you : M-unit just for entire new rewiring. That's i'm going to do...
For Electrex RR, yes they provided a diagram. Very easy to install, just remove the Regulator and diode board and then plug the new on to alternator and battery, That's why my question : the RR fits pretty well under the front cover at the place of the diode board... it fits so well, and will be hidden... but no air flow... or I should make a trap with a grid on the cover...
which could be another idea...
I'm going to post some pictures  ;)
Re: electrex RR45
« Reply #8 on: January 22, 2016, 03:21:22 PM »
There is some air flow via the intake vents in the bottom of the front cover. It flows out via the starter cavity top cover.  The top cover has been designed to create a negative pressure above it to encourage the air flow. Whether there is enough cooling air flow is the question.  It's enough flow for the stock components. Is there any reason why the new components should create more heat.
Offline guyom
Re: electrex RR45
« Reply #9 on: January 25, 2016, 10:45:04 AM »
HI Barry. Thanks for precision. About your question
Under the front cover, there's just the diode board... and not the regulator, which is under the tank. The Electrex RR45 has a big heat sync to cool down the electronic part. As bob said it uses Zener diodes so does it need to have important air flow... I try to contact electrex but no answer. Anyway for the moment i put it under the tank, behind the place of the 3 relays which are going to be remove. But definitely, under the front cover should be great.
Investigation continuing... Thanks guys!
Offline skippyc
Re: electrex RR45
« Reply #10 on: January 25, 2016, 07:05:30 PM »
I have only experience with podtronic regulators for English bikes and they use thyristors which dissipate a little less power than a Zenor. if you use power consuming devices on your bike they don't generate much heat and neither will a zenor.
Offline guyom
Re: electrex RR45
« Reply #11 on: January 26, 2016, 11:08:02 AM »
Thanks skippyc. I tempted to place it under the cover. I will explain my hesitation : if i place it under the front cover, i need to cut the wire and let 15cm the RR45 was closed to the alternator. And remove the connexion wire. I put it under the tank the RR45 was far from the alternator and need to have at list 30cm of wire...
anyway...
Offline guyom
Re: electrex RR45
« Reply #12 on: February 01, 2016, 02:01:04 PM »
Hi guys, to conclude the topic on RR45 : Electrex answered me and do not recommend mounting it in the original location in the engine, best to place it somewhere where it has some air flow.
So under the tank !
