Author Topic: Simple Carb  (Read 7305 times)
bubby-joe
Re: Simple Carb
« Reply #15 on: May 12, 2012, 01:56:44 AM »
I still have in cupboard just over my head a POSA fuel injector from the early 60's flat slide 1 moving part a tapered needle turn on gas kick and go best flat track carb I ever had.  I also have all the setup gauges that came with it I had it on a 45CI 48WL way better than the  brass linkirt fire hazard almost crispied my butt carb .
bubby-joe
Re: Simple Carb
« Reply #16 on: May 14, 2012, 07:51:45 AM »
A couple of spares might just fill the ticket here.
After yesterdays trouble with the Bings just about anything would be better carbs were rebuilt a little over a year ago and are now acting like the diaprams are gone again, caused me to miss the second best ride day of the year so far.  The POSA I have is a 2 bolt mount 32mm but I have access to a lathe so making it into a flange mount for my R-65 would be easy.
« Last Edit: May 14, 2012, 07:53:50 AM by bubby-joe »
bubby-joe
Re: Simple Carb
« Reply #17 on: September 10, 2012, 12:15:06 AM »
wirespokes if the offer is still good PM me.  The Bings failed all rubber parts melted down crappy ethanol fuel.  Do you have one or two of them.
Let me know....
bjamesw
Re: Simple Carb
« Reply #18 on: October 27, 2012, 11:15:06 AM »
I've got an '80 (austrian) Puch moped sitting in the garage next to my '83 R65.   Bing carbs all around.  The difference in complexity between the 49cc moped carb and the 650 R65 carbs is pretty remarkable.  On an order of dozens and dozens of parts.
Ironically, the highly complex R65 Bings have seen 15X the miles that the  #^@@(%@ little 14mm moped Bing has seen and given me 15X less trouble and headaches.   I can never seem to keep that little bastard vacuum tight, it leaks bodily fluids like a cheap diaper no matter how well it's maintained or adjusted, and generally just runs well when it's in a good mood.  I keep threatening to replace it with a little mikuni but never seem to get around to it.
« Last Edit: October 27, 2012, 11:20:59 AM by bjamesw »
