Author Topic: Master Cylinder  (Read 4168 times)
Re: Master Cylinder
« Reply #15 on: August 15, 2008, 07:34:54 PM »
Sometimes you can get lucky, I have before...
Re: Master Cylinder
« Reply #16 on: August 15, 2008, 09:18:42 PM »
If the pitting is not too bad, it can be honed.  I used a dowel rod, cut a slit down one end, and stuck some high# grit wet/dry sandpaper in the slot.  Put the dowel in your drill, and have at it.
Are you saying this is the first time in this whole deal that you have pulled the M/C apart???
ipanemaguy
Targabill
Re: Master Cylinder
« Reply #18 on: August 18, 2008, 06:44:58 PM »
Well, I just got the bike about 6 Days ago.. My K1200RS is to new to need brake work and my R50/2  has machanical brakes... So yes, first time pulling the MC apart...
Re: Master Cylinder
« Reply #19 on: August 18, 2008, 08:22:26 PM »
It's a pretty simple contraption.  Just clean, polish the bore, make sure all little holes are clean/open...
