Author Topic: Dead spots around 4-5K  (Read 8608 times)
Re: Dead spots around 4-5K
« Reply #15 on: November 26, 2006, 04:33:16 PM »
I have gotten my last couple of rebuild kits from Eurotech, about $45 for the kit with diaphragms, or $19.95 without.
http://www.eurotechmotorsports.com/forms/MyBike.cfm?q_brand=BMW
VaSteve
« Reply #16 on: November 27, 2006, 08:10:12 AM »
Thanks for the links, guys.  I will check them out.  I had so much fun riding the bike this weekend.  It's like I took the training wheels off!!  :)
ScottColumbus
« Reply #17 on: December 05, 2006, 03:03:40 PM »
Hi VaSteve,
do you have the old bing-carbs with the flat roof?
Is it looking like that?
The problem you describe is typically for that carbs. There is no piston-spring under the cover. The newer carbs do have this spring. I know somebody in the german Kleine-Boxer forum, who has developed and built this special spring for the old carbs. He is an engineer, his nickname is bang and you find him here:
http://kleine-boxer.redeker.net/profile.php?mode=viewprofile&u=289
I think 2 springs cost less than 5 $.
greetings from North Germany
Dirk
« Last Edit: December 05, 2006, 03:05:52 PM by ScottColumbus »
VaSteve
« Reply #18 on: December 05, 2006, 04:15:02 PM »
Sounds interesting, but where does the spring go and what exactly does it do?  Does it provide some sort of resistance for the diaphragm to push against?  If so...why?
ScottColumbus
« Reply #19 on: December 05, 2006, 04:51:49 PM »
Hi Steve,
I suppose you know this website:
http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?mospid=47851
There I took this picture from, were you can recognize the position of the piston-spring (No 7) of the newer carburetors. The spring stabilizes the up and down movements of the piston. But unfortunately this spring does not fit into your carburetors.
cu
Dirk
