Author Topic: Not always BMW...  (Read 7272 times)
Re: Not always BMW...
« Reply #15 on: December 02, 2008, 04:05:07 PM »
The top is down so much, I'm deleting the AC system during the Thanksgiving holidays. Will lose 22 pounds off the front end and pick up 7-10 hp due to eliminating the drag that the compressor adds even when the AC is off. Should bump up the fuel mileage a bit.
OK, it's been about a month since this last posting and Thanksgiving is over. Yes, I did do quite a bit of Cabrio work for a few days; interspersed with family gatherings and a couple R65 chores.
Good intentions but "it's always something". Pulled all the underhood AC hardware and a buncha other stuff just to access and replace a weepy water pump. Last shop quote for that job was $900+... No kidding. Lotta labor hours and not much for parts. My parts cost was approx $60 so I feel like I came out dollars ahead. No leaks from the new pump either.
Also replaced a transmission mount that had the rubber "cushion" split in half. Fairly simple job if you consider jacking up the gear box "simple".
To complete the AC delete required pulling the crankshaft pulleys driving the accessory systems. Evidently the PO, or more likely some ham-fisted shop mechanic, had rounded out the four Allen screws that attached them. Had to drill 'em out- like removing aircraft rivets -and get some new ones. Time's a wastin'...
The biggest fly in the ointment turned out to be another long, big Allen screw that I never did get out. Secures the pivot point on the AC compressor.  This forced me to re-fit the AC compressor body just so all my V-belts would line up.
Bottom line... I did get most of the Cabrio chores completed but left a couple for another day. Had to save some time to get the '81's bean can re-fitted plus the usual household chores.
I need to get back to the job just so I can get some rest! All in all, a pretty nice holiday break from the work place.
« Last Edit: December 02, 2008, 04:06:27 PM by montmil »
« Reply #16 on: December 02, 2008, 05:55:06 PM »
Monte, you have my unswerving admiration!  I still haven't finished my latest R65 chores.  Servicing's done, so's the routine maintenance,  Just can't seem to get around to finishing the reassembly.  You know.... too cold in the garage,  Friend's car need's my attention,  Leaves need blowing,  son needs Dad's help at his house, rental property needs attention.  R65 seems to always come in last  :'(
However,   Wife's leaving Thursday morn to spend weekend with girl friends in North Carolina mountains.  So far only a short "Honey Do" list, so by Sunday the R65 should be back on the road!
Gotta get back in the saddle & try out my Christmas/Birthday present..  Olympia Riding pants!!  What a fashion statement!
MultiplexMan
« Reply #17 on: December 31, 2009, 02:12:13 AM »
Monte,
The Mk1 was notorious for bad earths.  Always fun searching, cleaning and refitting all the earths.  A bit like an Easter egg hunt... If you have the first generation fuse box with the ceramic fuses - more joy...  Check for water ingress from behind the fuse box.  ::)
Great car when they are sorted.  Schrick made a very nice cam for the early 8V motor.  Neuspeed in the US make some heavy duty engine/transmission mounts too.  Go the rubber versions - a bit more durable than the polyurethane...
« Reply #18 on: December 31, 2009, 07:00:29 AM »
Monte,
Hey, Multi.  Earths=Grounds. Same all, same all. [smiley=thumbup.gif] Not only do I keep all the OEM earths tidy, I have added a couple extras upon suggestions from my favorite Cabriolet forum:
http://forums.vwvortex.com/zeroforum?id=152
Dumping the Euro ceramic fuses for modern was done on the Cabriolet and both R65s. Unless maintained, the evil water can invade behind the underdash fuse box. Me be dry.
The younger bling-bling crowd seems attracted to polyurethane suspension, steering and motor mount bits. Such a harsh ride. Quoting Madeline Kahn as "Princess Nympho" in History of the World, Part 1, "You're shaking my tits off!"
azcycle
« Reply #19 on: June 10, 2010, 11:18:48 AM »
Trish (my fiance) had a 99 Cabrio that was fun, at first.  But very slowly thing started breaking on it and it soon became a huge money-pit.  Power top pump broke, mystery dashboard idiot lights would come on for no reason, a/c condenser would go out intermittently, passenger window assembly broke 3 times (at $200 per instance).  The window was the most frustrating, as the part that continually broke was a small plastic pulley for the window mechanism... but you couldn't but that pulley... you had to buy the entire assembly. After the third time, we gave up and sold the car on Craigslist "as-is."
Granted, the car had a salvage title from a previous owner so I think much of it's problems stemmed from that, but still....
I've heard that newer VWs are just a nightmare to maintain after they hit the 5-10 year mark.  Too bad... they're great little cars...
I really want a late 60s-early 70s MarkIII Wagon.  :D
vvvvvvvvv
« Last Edit: June 10, 2010, 11:20:59 AM by azcycle »
« Reply #20 on: June 10, 2010, 03:33:05 PM »
Wow, Graeme... the "not always" original post is almost two years old. You are definitely surfing... Arizona.
The Mk1 Cabriolets are much easier to maintain. Manual top, manual windows, manual labor... Parts are mostly available and I do about 90% of all the maintenance on the car. Have owned the '86 for over eleven years as the second owner.
After Lynn and I return from a break on the Texas coast -no beach oil, it's all next door at LA and FLA- I'm replacing the engine mount rubbers and completing the AC delete option I started last year. Six more months and the car will be exempt from emissions testing since it will be classified as an antique... like me!
