Author Topic: changing rear wheel  (Read 3734 times)
thrang
changing rear wheel
« on: April 18, 2007, 07:30:38 PM »
I'm thinking about having another go at modding a rear mudguard. Has anyone tried fitting a sprung hinge? My last version involved having it detach just infont of the rear light mount. I attached it using a shaped piece of metal under the guard hooked on to a hanger on the frame and a couple of pins on the plastic.  It worked alright but in the end I binned it after the number plate and guard came off when I was being a little to enthusiastic on a fast a road.
Having just had a right struggle to change out the wheel in the dark after the new beemer got a puncture I'm looking at an old rear mudguard and thinking about a sprung hinge to stop it bouncing free?
Re: changing rear wheel
« Reply #1 on: April 18, 2007, 08:22:57 PM »
You might examine a pre-'70 (/2) mudguard to see how it was done.
Myself, I tie the centerstand in place to the exhaust crossover,
then I remove the front wheel (easy - single brake)
then I tilt the bike forward (hope you didn't just fill your fuel tank...) till it rests on the fork legs,
and then I remove the rear tire.
Get a block on which to rest the final drive, and tilt the bike back.
« Last Edit: April 18, 2007, 08:23:10 PM by Rob_Valdez_79_R65 »
« Reply #2 on: April 18, 2007, 10:25:54 PM »
My problem is always to tug the tire out between the brake shoes and the left side of the frame; maybe the crack in my rear fender is why those are my worry points.
I like to put a 2 x 4 board under my center stand, since I have the dual front disks and removing the front tire is a bit of a pain.  My Windjammer weights the front down nicely with the rear tire out.
The hinge idea sounds great, though, and has been used on several loved marques.   ;)
« Reply #3 on: April 19, 2007, 02:05:06 AM »
I will agree that every rear tire in recent memory (you know, the part that still works?) I have installed, I have to deflate the tire in order to get it between the brake shoes and the swingarm.
With my tilting-up method, my luggage racks are no longer an issue.
thrang
« Reply #4 on: April 19, 2007, 06:22:28 PM »
Cheers Rob. Dropping the bike forwards on to the fork legs is a cracking idea.
Doh why didn't I think of that?
Probably because I am an idiot.
Tony
« Reply #5 on: April 20, 2007, 02:21:39 AM »
Don't forget to secure the centrestand!!!   :o
« Reply #6 on: April 20, 2007, 08:59:39 PM »
I don't have to deflate the tire.  I use 110 width Spitfires.
« Reply #7 on: April 21, 2007, 01:34:52 AM »
That is what mine is - 11R  110/9018 M/C  61H
(shrug?)
Here is the picture I promised
« Reply #8 on: April 23, 2007, 06:35:28 AM »
click for full size
« Reply #9 on: April 27, 2007, 08:05:37 AM »
Early BSAs also had a hinge!
