Author Topic: Adjustable heel-toe shifter prototype  (Read 3063 times)
trolle
Re: Adjustable heel-toe shifter prototype
« Reply #15 on: August 06, 2008, 04:21:32 AM »
second that
greetings from a partly sunny north
trolle
« Reply #16 on: August 06, 2008, 06:48:01 PM »
I would go for somthin' that allowed rear peg shiftin' while keepin' the front lever. I'll even offer up my bike as a test bed. That bike you got the heel / toe setup on Justin looks like it don't run ;D
« Last Edit: August 06, 2008, 06:48:57 PM by MrRiden »
« Reply #17 on: August 06, 2008, 10:48:24 PM »
It runs but is ugly and not registered...
flatlander
« Reply #18 on: August 09, 2008, 12:20:33 AM »
Neat shifter, I like it! Don't distress over the tig vs. mig deal. Any prototype is about function first - right? Judging visually that weld is an inert gas weld with like .045 wire and it is w-e-l-d-e-d. Maybe try this, use a little .035 or smaller flux-cored wire and take the gas nozzle off your mig gun. This will allow a bit more precision as the nozzle is gone and the contact tip is all you have to deal with. The contact tip is electrically hot but it is easy enough to keep it off the work or you could just insulate it. Don't try a continuos weld... just a quick puddle then release and do it again. Kind of like spot welding but the object is to do a series of circular spots each of which covers the last about 40-50%. Done quickly the puddle never cools enough to prevent admix of the filler with the previous dot of weld. You'll get the hang of it quickly and produce welds that rival the appearance of any tig weld - will kinda look like a stack of tiny dimes wrapped around the flange of your shifter. I own 3 tig machines and I am well aware of the public mystique with tig processes... sure tig works great on al, ss, c-moly etc. but mig does too and is way faster and certainly the standard of production now; after all, tig is little more than an electric torch! If you want to stay with a continuous gas weld build a spindle fixture to turn the piece on and have a buddy turn the whole thing while you stay in place and weld - or a fixture to hold the gun while you pull the trigger and turn the work. Just my long-winded two-cents worth...
« Reply #19 on: August 09, 2008, 07:53:47 PM »
It was actually with .035 or .030 wire, I'll have to look at the spool.  My problem is that one the arc is struck and my lens darkens I can't really see anything except the arc.  I need to put a flood light on the work so I can see what I am welding on.  I had the same problem in school, nice pretty beads but I would start getting off track after an inch or so.  I'll try the "stacked circle" method.  I made another attempt the other day, gobbed on a bunch of weld, then put it back in the lathe to bevel the weld bead - jury's still out on that method.  I really need a rotary table for my mill then I could mount the part and use a ball end-mill to clean things up.  I think I feel a purchase coming on...
