Author Topic: No start up  (Read 3321 times)
Offline BooG
Re: No start up
« Reply #15 on: July 17, 2008, 09:49:55 AM »
Good call on the solar panel. Might look up the thread and explore that one.
Latest test results show up ok. At 2000 rpm, the multi-meter is heading up from 12.8, and by 3000rpm it was 13.5 and still climbing. The voltage increases slowly but steadily, so if you took a few readings they would all be different, but increasing. I have one of those solid state voltage regulators in that are supposed to be better for slower traffic situations. Seems good to go at the moment. Should be able to turn my attention back to the speedo!
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: No start up
« Reply #16 on: July 17, 2008, 10:57:01 AM »
At 13.5 v it is charging - slowly!  My '81 R100 runs between 13.5 and 13.9 depending on ambient temperature - and that with a new rotor, brushes, and fixed solid-state regulator...
Offline BooG
Re: No start up
« Reply #17 on: July 17, 2008, 11:12:50 AM »
Yeah, I may well look at that solar thread again..could be a good move.
Recent multi-meter readings are better. As revs slowly increase, so do the readings. It was up ti about 13.8 at 2500 and still rising. The voltage increase is slow but steady. I have one of those solid state voltage regulators, not the stock one....don't know if that makes any difference to readings.
All running well at the mo. Back to that pesky speedo then!
BMW R65 1980.
BMW K75S 1987
Offline BooG
Re: No start up
« Reply #18 on: July 17, 2008, 11:22:58 AM »
I think I already posted?!?
BMW R65 1980.
BMW K75S 1987
