Author Topic: New Opinion Of Metzeler Tires And EBC Brakes  (Read 1223 times)
« on: July 13, 2008, 07:20:49 PM »
We had a fierce thunderstorm here in the Phoenix area when I was getting off of work today at 16:30.
This is the first real test of the EBC steel floating rotors, and graphite brake pads in really wet conditions.
I have to say that I am impressed with the brakes, I had 10 miles of 'flooded' roadway ( 2inches of running water across the pavement), on Interstate 10, when I got off of the expressway, I had braking power almost as good as when they were dry, I went through 2 flooded intersections ( 6-10 inches of running water ), and still no brake fade.
The Metzeler tires gave me no problems at all, so I have changed my opinion of the ME33/ME99, and the Lazertec series tires.
The original OEM stainless rotors, and OEM pads were completely useless in wet conditions, so I didn't have a good opinion of the Metzeler tires until today.
« Last Edit: July 13, 2008, 08:57:12 PM by Bob_Roller »
VaSteve
Re: New Opinion Of Metzeler Tires And EBC Brakes
« Reply #1 on: July 13, 2008, 08:46:59 PM »
The shop that put on my tires said that the new compounds are a lot sticker than they used to be.  They had a hell of a time getting the front tire's bead to set properly.  They said in the old days they would just pop into place...now they take a lot of coaxing since they get hung up on the rim.
« Reply #2 on: July 14, 2008, 08:04:12 AM »
Steve, the Macadams are the same way.  On my tubeless rims they "pop" like they should but on the snowflake rims I have to put in around 100 psi and even then they just slowly "crawl" into place - even with things well soaped.
« Reply #3 on: July 14, 2008, 10:07:40 AM »
... I have to put in around 100 psi and even then they just slowly "crawl" into place - even with things well soaped.
Ditto the 100psi with my new Bridgestone Spitfires. Felt like I was an EOD guy. Needed longer arms.  ;D
« Reply #4 on: July 14, 2008, 10:54:07 AM »
I have a clip-on tire chuck so I attached it, put it outside around the corner, and cranked up the regulator while I was hiding...  So far nothing has ever let loose and I've been changing these for about 5 years now.  I don't remember this issue way back when when tires were meant to run with tubes.  They seemed to seat better and were a lot more flexible and easier to get on the rim.  I used the BMW tire pump numerous time (I had to fix 5 or 6 flats on the AL-Can Hwy.) and was able to get everything seated OK with the old Conti Twins.
mikethebike
« Reply #5 on: July 15, 2008, 05:18:44 PM »
I recently fitted a Metzeler 400 18 "Perfect" tyre  (tubed) on the front.  It was a pain to fit and took several inflate, deflate, reinflates before it seated properly.  No problems now it's on. Does the job!  (EDITED- Should read 3.25 x 18) Sorry!)
« Last Edit: July 16, 2008, 01:49:57 PM by mikethebike »
Offline beemer
  • The Red Tomato!!!
« Reply #6 on: July 16, 2008, 10:12:49 AM »
What make and size have you got on the back?
mikethebike
« Reply #7 on: July 16, 2008, 01:48:39 PM »
Sorry!  It's a 3.25 x 18 on the front (I'm getting senile!!!)  I have a Pirelli Supersport 4.00 x 18 on the rear at present but may soon be replacing it.
