Author Topic: New R65 member; Berkeley Calif.  (Read 12146 times)
Andrew
Re: New R65 member; Berkeley Calif.
« Reply #30 on: February 04, 2010, 11:52:07 AM »
I agree re the needle cage; it's very short for the length of the available opening in the shifter proper. I had thought maybe a longer bronze, brash, etc. bush could be made up and pressed in, but as long as the orig part was available I figured I'd go with it.
So "progress" on the forks. Pulled off the fender, instruments, wheel and caliper, last night, getting down to the nitty gritty. Undid the four pinch bolts on the triple clamps (tree) and expected the forks would just fall out. Ha! This thing is fooked! The bends in both forks had them well jammed into the lower clamp. Eventually I pulled off the bars and removed the upper clamp, no problem, with minor tapping with a plastic mallet. But the forks were still uber-jammed in the lower clamp.  Pounding with a sledge resulted in some movement, but not much. Heat and WD40 helped, but by the time the top of the fork tube got down to the lower clamp, it was flared enough from my enthusiastic pounding that it wouldn't pass through; it's a very close fit.
So I undid the steering head nut and just pulled the whole fork/clamp assembly off. Now I need a new triple clamp, but (1) I'm not really surprised, and (2) that's probably good considering how much stress it received from the forks' bending. Got a line on a couple, so I should have it in had early next week if all goes well.
See pics.
Andrew
« Reply #31 on: February 04, 2010, 11:57:47 AM »
The R65 triple tree and upper triple clamp, is R65 specific, the larger bikes had a different set-up .
Andrew
« Reply #32 on: February 04, 2010, 12:37:53 PM »
There are several on ebay. Checking PNs to make sure.
Andrew
« Reply #33 on: February 05, 2010, 06:39:58 AM »
Yes they are wider that the larger models and have a different offset.  they come up regulalry in the UK and are faily cheep.
So you shold not have a problem locating a set.
Or better still look cfor a complet front end - you need new tubes anyway.
Are you sure your fram is good?
Steve Hawkins
« Reply #34 on: February 05, 2010, 10:37:08 AM »
Ours is better.
I would be worried about the frame too, that's a lot of force.  But I don't know how to check one.
Andrew
« Reply #35 on: February 05, 2010, 10:43:33 AM »
Yes, could have screwed up the frame, and that's a risk I took. But I've examined it all pretty closely, and I think it's OK. The triple tree is pretty massive, and between the force getting abated by the tire, rim, forks, and tree, I'm forging ahead on the assumption that the steering head is OK. The wheel, forks, and tree are all sacrificed, so I'll have all-new metal all the way up to the steering head.
Found a local guy (Don W.) who has R65 and other airhead parts out the wazoo, so I probably will buy a tree tomorrow locally, without having to wait for shipping, etc. Plus I can compare to mine to make sure it's identical.
Andrew
darrylri
« Reply #36 on: February 05, 2010, 11:37:26 AM »
I can't really tell from the photos you've posted, but if the flat gussets welded to the steering head are indeed still perfectly flat, then you should be ok.
Andrew
« Reply #37 on: February 05, 2010, 03:27:32 PM »
They don't look buckled at all; that did seem like a key area to examine.
Andrew
Andrew
« Reply #38 on: February 08, 2010, 12:28:57 PM »
Got a triple tree from Don Whiteside, just over the hills from Berkeley, and got it all reassembled Saturday. However, ebay wheel is very out of plane; wobbles side to side at the rim maybe 2" when spun. So that's no good. Once I find a wheel, fix the choke cable, a couple other little mods and fixes, change the fluids, will be on the road, I hope.
Andrew
azcycle
« Reply #39 on: February 11, 2010, 03:26:14 PM »
Way late to this thread, but welcome from a newbie to the r65 world. Looks like you've got a very nice project there.
Andrew
« Reply #40 on: February 16, 2010, 11:15:44 AM »
Put an ad on ibmwr and got various responses for 18" wheels, including one from Rob W in Santa Cruz, so I popped down there yesterday morning and picked it up, along with some odds and ends, and got a choke cable from Don W.
Put it all together yesteday, finished changing fluids, bled front brake, changed oil filter, and hit the road. Bike works pretty well. Idle needs some help and handle bars still have a slight tweak, but all in all a functioning machine. Woohoo.
Andrew
« Reply #41 on: February 17, 2010, 09:38:52 AM »
congrats
"I Love it when a plan comes together!"
Who said that?
Steve
Andrew
« Reply #42 on: February 17, 2010, 11:21:46 AM »
I've been riding it every day to get used to it, and used to riding. I haven't owned a real bike since 1980 (Honda CL175). The Benellis don't count. This is fun.
I put the amazon.com-sourced R65 stickers (I cut off the "LS") on the painted side covers last night and will put them on the bike today. Next stop, valve adjustment.
Andrew
darrylri
« Reply #43 on: February 17, 2010, 02:45:31 PM »
Don't forget to zip tie those sidecovers in place, lest they depart while you're on the road.
« Reply #44 on: February 17, 2010, 05:45:09 PM »
congrats "I Love it when a plan comes together!" Who said that? Cheers Steve
The line is by Colonel Hannibal (George Peppard) Smith, not Hannibal Lecter, and from the classic TV action show, "The A-Team". Lots of car crashes, explosions and gunfire... but no one was ever killed! Amazing...
For more stuff on The A-Team... http://www.imdb.com/title/tt0084967/quotes
I never missed it. Therapy didn't help.  ;) Monte
« Last Edit: February 17, 2010, 05:47:12 PM by montmil »
