Author Topic: oil drain plug  (Read 751 times)
awaffa2003
oil drain plug
« on: June 30, 2008, 08:36:23 PM »
hey guys! just wondering what size thread the oil drain plug is. i'm getting the oil temp sensor for the Vapor. I think i'll like the wiring better because i don;t like the wire coming off the sparkie. still haven't got that tach right yet...gotta talk with monte...
samc
Re: oil drain plug
« Reply #1 on: June 30, 2008, 09:16:39 PM »
16 mm X 1.5, I believe. Not the standard thread.
Re: oil drain plug
« Reply #2 on: June 30, 2008, 09:24:46 PM »
Yeah, I had to go back to the Vapor manual and confirm the correct "pulse" setting for our R65s.
Remembering that the Beemer ignition "wastes" a spark on each cylinder; the plug actually fires on the exhaust stroke on one side as the other cylinder is firing on the power stroke.
I programed the Vapor for a "2 PPS" rather than the default setting of "1 PPS" and everything seems to read correctly. Tricky, since the coil fires both plugs at the same time... hence the so-called "wasted" spark. Left at the default setting, the tach's electronic brain thinks you're riding a 2-stroke. Horrors!
« Last Edit: July 01, 2008, 05:28:06 PM by montmil »
