Author Topic: Reconditioning Completed  (Read 4203 times)
Re: Reconditioning Completed
« Reply #15 on: April 27, 2009, 08:05:56 AM »
Stan, I've found "Greased Lightning" which, although I don't think there is any acid in it, is a highly aggressive high alkaline concentrated cleaner.  It even does a pretty fair job as a piston top soak for softening up thick carbon deposits.  I usually to the scrubbing with Greased Lightning and when clean I use the Eagle 1 to try to get out any dark staining.  Seems to work fairly well...
vestandpants
« Reply #16 on: April 28, 2009, 06:18:45 AM »
I scrubed mine with vinegar, being a mild acid and very cheap @ £2.25 a gallon. I didnt just dip it, I used a plastic based scourer used for paint preparation. It lifted most of the dirt off although it was more of a challenge doing the fins on the heads. All thats needed is elbow grease!
Offline CraigC
« Reply #17 on: April 29, 2009, 02:36:33 PM »
Hi Stan,
Just wanted to congratulate you on a great looking restoration. I have a red 81 R65 with 25K miles in similar condition to yours before you freshened it up. Since we both live in Baton Rouge, I was wondering if you'd mind answering a couple of questions. First, did you paint or powder coat the frame? Also who did you use for this work? Did you use a local painter for the tank and other bits? I intend to do almost exactly the same thing to mine as you did.
Thanks,
CraigC
StanG
« Reply #18 on: April 30, 2009, 07:59:25 AM »
Hello Craig,
I used several different people for the work.  I can give you the info here or we could get together and discuss.  Would you like to meet for lunch, after work, or at Hebert Cycles on Saturday morning?
Stan
Offline CraigC
« Reply #19 on: April 30, 2009, 11:08:11 AM »
Thanks Stan,
PM sent...
Reopropf
« Reply #20 on: May 13, 2009, 06:34:45 PM »
Stan,
Beautiful job.  I love the look and appreciate the work involved and expense.  It's "new" and original.
I hope to achieve similar result with my LS.
Thanks for the tips on cleaning and cover specific powder coating.
Regards, Peter
ambrose78
« Reply #21 on: June 17, 2009, 03:07:15 AM »
very inspiring.
Getting lots of urges to do similar things to my bike now.
Congrats.
