Author Topic: I just got a R65  (Read 10376 times)
Re: I just got a R65
« Reply #30 on: March 12, 2007, 12:20:26 AM »
Good eye, Bob.  My guess would be '81 or later, and the speedometer has been replaced with an earlier unit.
Note the square airbox and non-flat top carbs.  And the seat is from a "2nd generation" R65, also.
Shannon, locate the fuses, and we'll know for sure.  They are either behind the right side cover (1st gen) or under the rear of the fuel tank (lift the seat and remove the tool box), which would indicate '81-'84.
The easiest way to tell, of course is the serial #.  This is a 7 digit number.  On the engine, it is next to the oil filler hole.  On the frame, it is stamped into the steering head reinforcement on the right side of the bike.
If they match, that is good.  If they don't, it means the engine has been replaced at some time.
Go to this website and put in the serial #(s) and it will tell you the date of manufacture:
http://www.bmw-z1.com/VIN/VINdecode-e.cgi
Go to this site, and put in the serial #(s), and see if it has ever been registered here.  If it has, you might get some history on it: http://www.micapeak.com/reg/bikes/R65/
« Last Edit: March 12, 2007, 12:23:09 AM by Rob_Valdez_79_R65 »
Flora_Max
« Reply #31 on: March 12, 2007, 01:15:08 AM »
Thanks all,  It is apparently a 1987 model.  with 63000 in the clock.  All it will cost me is the cost to register. Has been in storage for 10 years.  Has had the brakes serviced and fluid changed.  Work on the carbi's has been done.  Replacing battery and Tyre's at a recommendation from the mt Nardi Yacht Club.
Thanks again.
Shannon
Flora_Max
« Reply #32 on: March 12, 2007, 02:25:52 AM »
Rob, can you please explain to me about 1st and 2nd generations (Briefly).  I wish I had it home to check the numbers.
Bob, the marking on the speedo is something we will have to guess at.  Hopefully its not the flat spot indicator!
« Reply #33 on: March 12, 2007, 07:12:33 AM »
Shannon, it can't be a 1987 model, it can be no later than an '84 ('85 in some parts of the world).  That is the year breakpoint where they switched to the same monoshock rear suspension and frame as the rest of the Airheads.  It is an interesting combination!  Rob nailed a real good item to check as far as the fuse holder is concerned.  Another thing to check would be whether the front brake light switch is a pressure switch (on a bracket screwed into the brake-line splitter underneath the clutch lever) or a small push to actuate switch in the R/H perch assembly.
Of course, you can always ruin all of our "game-show" type fun and run the VIN number which will reveal the month/year of manufacture!  :)
« Last Edit: March 12, 2007, 07:20:25 AM by admin »
« Reply #34 on: March 12, 2007, 11:43:44 AM »
1st generation - model years 1978 - 1980 ~ points ignition, cast iron cylinders, smaller valves, flat top carburetors, round front brake fluid reservoir, hydraulic activated front brake switch - to name a few.
2nd generation - model years 1981 - 1984 ~ electronic ignition, Nikasil cylinders, larger valves, dome top carburetors, rectangular brake fluid reservoir, mechanical front brake switch.
3rd generation - model years 1985 until they quit ~ The year the twin-shock chassis went away across the full line (for the U.S.).  Except for displacement, the R65, R80 and R100 standard motorcycles were identical.  Benefits of these bikes - true tubeless wheels, single sided swingarm making wheel removal simple and eliminating a few weaknesses in the final drive configuration.  A harder (chrome?) plating on the tranny input shaft, extending the interval of maintenance.
 [smiley=2cents.gif]
Of course, all of these changes vary depending on where one lives.  The US did not get the R65 until 1979.
And I think I remember reading that the R65 was still manufactured right up until the end in 1994, for certain non-US markets.
Flora_Max
« Reply #35 on: March 12, 2007, 08:31:41 PM »
And some more
Flora_Max
« Reply #36 on: March 12, 2007, 08:32:18 PM »
and more
« Reply #37 on: March 12, 2007, 08:51:05 PM »
Still no serial #?
Interesting graphic thing on the headlight...
I heard about you and your dirt bikes... ;)
I just looked at the 1st pictures again.  It appears you may have 4-way flashers on that bike!
See the "button" between the instruments?  If you depress that in conjunction with one or the other turn signals activated, it should make all 4 flash!  It looks like it has been painted black, though.  Mine is red.
« Last Edit: March 12, 2007, 08:59:23 PM by Rob_Valdez_79_R65 »
Flora_Max
« Reply #38 on: March 12, 2007, 11:16:55 PM »
Love the GPS on the handle bar!
« Reply #39 on: March 13, 2007, 03:27:41 AM »
Do they have GPS in Oz?  ;)
Yeah, it is my accurate speedometer.  :-/
It is also my trip meter (fuel gauge) since I dumped the bike and broke off the reset knob.  But that only works if you take it on EVERY ride!
It is nice having a better idea of how fast I am really going, though.  Today on the way to work, it read 30 mph, and my speedometer was steady at 40.  Could you imagine how mad the drivers behind you would be if you believed your speedometer?
Here is my photo essay on mounting it on the bike.
« Last Edit: March 13, 2007, 03:29:40 AM by Rob_Valdez_79_R65 »
Flora_Max
« Reply #40 on: March 13, 2007, 04:29:09 AM »
Yes we do have GPS.  I never thought of using it like you do Rob.  I bought mine to find the back boundary points.  Try and find a 4" x 4" white peg sticking 8" out off the ground in thick rainforest.  The Rock Valley post office is easy.
« Reply #41 on: March 13, 2007, 06:26:11 AM »
Rob, thanks a lot for your GPS photo essay. Strangely enough, I've been watching some small units on eBay (cheaper than I'd thought) &  was thinking yesterday about PM-ing you to see if you could put up something similar to this! [smiley=thumbsup.gif] You've always got great documentation!
My biggest concern would be the visibility in direct sunlight: valid?
Also, battery drain & theft, or are you able to easily remove when leaving your bike for any length or time, or unattended?
Thanks.
« Last Edit: March 13, 2007, 09:48:29 AM by NC_Steve »
Flora_Max
« Reply #42 on: March 15, 2007, 05:48:06 PM »
OK and the winner is ?   Not yet sure.  Vin No 6311290 with the date 11/80 so rob Roller is the closest.
« Reply #43 on: March 15, 2007, 07:18:03 PM »
That would make it a US model year 1981, at least you should have Nika-Sil cylinders, and stuff...
