Author Topic: Aftermarket carburetor o-rings  (Read 2372 times)
« on: May 25, 2020, 02:20:09 PM »
I recently rebuilt my carbs.  I got the bowl/enrichener gaskets from the local dealership (diaphragms/floats/needles had already been replaced), but I couldn't bring myself to spend $3 a pop on some tiny little o rings from BMW.
I used Anton Largiader's site to size my o-rings.  Unfortunately his sizing of the main jet holder is a little bit off.  I would recommend a 2mm x 8mm o-ring for that application.  I had to scare something up out of a kit I had in the garage for those, which I wasn't happy about because it didn't list the rubber type or hardness (durometer rating).
Nevertheless, you can get enough O-rings to rebuild your carbs 20 times (not including throttle shafts) for about $20 including shipping.  I chose Buna-N o rings at 70 durometer.
Enrichener 1.5mm x 5mm
Idle jet/pilot screw 1.78 x 2.9mm
Main jet holder 2mm x 8mm
I purchased them from theoringstore.com.  I have no affiliation; they just have a good selection and the prices are reasonable.  Also, you know exactly what you're getting as far as rubber type, size, and hardness, which is important for this application.
« Last Edit: May 25, 2020, 02:24:21 PM by Luca »
Offline wilcom
Re: Aftermarket carburetor o-rings
« Reply #1 on: May 25, 2020, 02:40:03 PM »
 Very good info, Luca. Thanks for posting
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline BPT
« Reply #2 on: May 26, 2020, 01:29:53 PM »
Yeah, thanks for doing the legwork and posting this Luca.  This is good to know.
« Reply #3 on: May 26, 2020, 04:11:21 PM »
I do much the same Luca.
When i first bought the bike 14 years ago I found a couple of O ring kits, one metric and one imperial. Between the two I have O rings to fit everything. They are also standard Buna- N nitrile which seem to work well enough.
The one O ring I did buy as a specific spare part was the oil filter $2000 O ring which turned out to be a disappointment as is was supplied as a standard black 70 shore O ring rather than the the original soft white O ring which comes with proper filter kits.  I've never used it as won't compress easily enough to allow the filter cover to tighten up flush.
« Reply #4 on: July 18, 2020, 11:22:35 PM »
And then there is the much improved after market  Quad ring for the brake shaft
