Author Topic: stainless steel braided brake lines  (Read 6841 times)
Re: stainless steel braided brake lines
« Reply #30 on: January 31, 2019, 03:48:22 PM »
I also wounder about how difficult it is to re-sleeve it down to a smaller size as I have a good working master cylinder now.
Easy job if you have the machine tools, the hardest part is setting up the correct level of interference so that brake fluid doesn't leak out between the cylinder body and the sleeve.
Even if you pay a brake shop to do the sleeve it will still be cheaper than the cost of a new master cylinder.
Offline davidpdx
« Reply #31 on: March 29, 2019, 08:28:35 PM »
Well the R65 forum does it again. After putting new braided brake lines and organic pads on I was still not satisfied with my front brake. It turns out I had a 15mm master cylinder mounted. Thanks to Mrclubike and Tony for explaining the need for a smaller MC I bought a 12mm off a wrecked R65 and mounted it today. I can't quite lock up my front tire but it dives down hard and scrubs the speed off nicely. Thanks for all your help guys, what a great resource. You may not have saved my life but then again you might have. David
1984 R65 60K+
1946 Triumph Speed Twin
? Hunter S. Thomps
« Reply #32 on: March 29, 2019, 09:46:28 PM »
You are Very Welcome
glad to helpĀ  :)
« Last Edit: March 29, 2019, 09:46:43 PM by Mrclubike »
