Author Topic: Do your exhausts "pop" on the over-run?  (Read 1350 times)
Offline beemer
  • The Red Tomato!!!
« on: June 02, 2008, 09:48:30 AM »
Iv'e had a good look at them but can't see any holes or air leaks?is this a common thing on the R65LS?i thought they may be sucking air from somewhere,but i couldn't see anything!!!give me some info guys,thanks,J.
Re: Do your exhausts "pop" on the over-run?
« Reply #1 on: June 02, 2008, 02:55:36 PM »
One cause of popping/mild backfiring through the exhaust system can be the pulse air injection system
(the plumbing inside the airbox and the pipes&hoses connecting from the airbox to the cylinder heads under
the exhaust nuts).  The vacuum lines are supposed to shut off the air injection to the headers when the throttle
is closed, but it doesn't always work perfectly well.   If your carbs are running a bit on the rich side this can happen
as well as some unburnt combustibles do make it through into the exhaust system.
On my LS, I can get some light pops/crackles if I run it up quick to around 6000  RPMs and quickly chop (let go) the throttle.
I still have the pulse air system and I am intentionally running the mixture just a little bit richer than absolutely
necessary to help keep the head temperatures down (running too lean raises head temps and can accelerate the
valve plastic deformation issue).    Except for this fairly drastic throttle condition, I don't have any "pops", which
I think is fairly normal for these bikes.   It helps me to be noticed by the multitudes of H-D riders around here,
who cannot hear my loud valves over their loud pipes ! ;)
Offline beemer
  • The Red Tomato!!!
« Reply #2 on: June 02, 2008, 04:57:33 PM »
Thanks so much for your reply,it's about the same as yours from your description,so i will leave looking for an air leak for now anyway,unless it gets really bad!!!cheers,J. :)
« Reply #3 on: June 02, 2008, 07:31:01 PM »
Air leak or malfunctioning "Fresh Air" system can cause a pop. See here: http://www.webbikeworld.com/Motorcycle-technical-articles/pulse-air/
Only because nhmaf mentioned loud H.D.s [Wisconsin Tractor Bikes]
« Last Edit: June 02, 2008, 07:31:33 PM by MrRiden »
« Reply #4 on: June 03, 2008, 04:55:02 PM »
Some of us are doubly thankful that we don't have the Californica-version of the R65. No air injection on my scoot. Yea!  ;D
Rich, love the sign.
Offline beemer
  • The Red Tomato!!!
« Reply #5 on: June 03, 2008, 05:07:48 PM »
It's not on mine either,i think it came in 91 here in the UK,cheers,J.
