Author Topic: Nikasil cylinder/Heat  (Read 1397 times)
Offline wilcom
« on: April 16, 2016, 04:37:21 PM »
I've only owned one BMW with Nikasil cylinders, a 82 R80. I've always thought that the Nikasil  liners on the 82 dissipated more heat than the ones without.
That 82 would blister my ankles without boots on a hot day
Anything to that? Maybe it was just warmer the years I owned that R80..................
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
Offline wilcom
Re: Nikasil cylinder/Heat
« Reply #1 on: April 16, 2016, 09:42:19 PM »
After reading a whole bunch of metallurgy stuff and wading thru GM production costs of cylinders( yyada yada yada) I found the answer in the good ol' Wikki.
" The aluminium cylinders also gave a much better heat conductivity than cast iron liners, "
That's why that R80 would burn my feet off in the summer time. A double edged sword to be sure. Burns your feet but gets the heat out of the motor
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #2 on: April 16, 2016, 10:20:51 PM »
Just look at it this way - adding an extra 4-5mm of iron sleeve is going to increase the amount of thermal resistance to the outside alloy of the cylinder compared to the very thin Nikasil coating on the alloy
Offline wilcom
« Reply #3 on: April 16, 2016, 10:34:45 PM »
I remember the Nikasil bike was VERY VERY uncomfortable in the summer time. A definite consideration when choosing between two bike. If I were going to put the miles on like a car it would be a no brainer which way to go.
Cars are different as you're not straddling the freaking motor so who cares about the heat, wear is the issue.
But on a bike  I never plan to wear out, do I really need neat last a long lasting  cylinders? I think not, I'll go with the comfort
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
