Author Topic: Best R65 Repair Manual?  (Read 6818 times)
Offline ShutterPilot
Re: Best R65 Repair Manual?
« Reply #15 on: January 28, 2014, 08:57:00 AM »
Ha! Montmil, I've been looking at lifts since I brought her home. It looks like accessing the cylinders would be so much easier.
But...
I'm also planning to need to do field teardowns, so a more portable unit would be desirable, but I haven't found a smaller lift to get 'round the pipes/frame/oilpan.
Perhaps after some research, I'l start a "lifts" thread, if there isn't already one floating around out there.
Oh, BTW, I discovered why this copy wouldn't get much over 75mph indicated - the left caliper sticks and doesn't fully retract. Looks like a calipers rebuild is now top priority. Doesn't appear to have warped the rotor (whew)
« Last Edit: January 28, 2014, 09:01:33 AM by ShutterPilot »
Offline DeeG
« Reply #16 on: March 17, 2014, 11:07:51 AM »
While searching ebay for a Haynes manual, I came across this seller:
http://stores.ebay.com/e-ClassicBike-Manuals/BMW-/_i.html?_fsub=1339913016&_sid=28787106&_trksid=p4634.c0.m322
Picked up the three that I needed, and they are a very nicely done reprint of the factory service manual.  Pictures and type are clear, and its spiral bound so i don't have to use a wrench to keep it opened to the page I want.
Dee G
1978 R45/N ?
1978 R80 w/hack
1971 R75 (swb)
« Reply #17 on: March 17, 2014, 12:04:24 PM »
Thanks DeeG
« Reply #18 on: March 17, 2014, 07:46:25 PM »
There was a thread on lifts a while back that involved price and space constraints.  There was mention of a cheap to make, DIY plywood table and the hydraulic floor jack types.
I have seen some conventional lifts with a very narrow platform that are compact and relatively lightweight.  If you or a friend can weld you might be able to build one, but the price of steel these days is pretty high.  Repurposing some scrap from a pick and pull scrapyard might make a homemade, portable lift more feasible.
« Reply #19 on: March 17, 2014, 10:17:49 PM »
It's hard to beat the HF lift as it's on sale most of the time.  Mine actually doesn't take up any room as when it's not being used as a lift it has a bike parked on it! ;)
« Reply #20 on: March 17, 2014, 10:41:18 PM »
Thanks for the link to those books, Deeg!   They could be another good resource and I may put in an order for one or two of them soon!
« Reply #21 on: March 18, 2014, 09:00:20 AM »
And depending on the size and ground clearance of your "cage', it is possible to park a 4-wheeler over the lift. Although my bride is firmly set against the idea... :-/
